Single and Dual Speed cooling fans
    ok on page 262 of the shop manual, it shows this picture below. What's the difference between the two? Does the dual speed always run?
    NOW WITH SPINNER HUB CAPS
    The fan runs at the lower speed when the car is moving slow and the higher speed is for when the boost kicks in
    '91 LX
    '03 Mazdaspeed Protege #235
    Originally posted by pigeon
