A while back I was planning on swapping in electric windows into my SE. I had everyhting includeing the wireing harness that runs under the carpet and to the back Pillars for the rear doors. I hooked everything up (for the two front doors) and the driver side worked fine, but the passenger side wouldn't work at all not on the master switch, or the passenger switch. So I thought that the motor/regulator was gone. Nope hooked the motor straight to the battery and it rolled down, switched the polarity and it rolled back up. So for some reason it wasn't getting juice from the harness through the door.
I came across some information that there is a Power Window relay, So the other day I went out and pulled all of the relays, and couldn't find the Power Window relay. Some of them are marked as to what they are, while others aren't.
Can anyone tell me which one is the power window relay? The relay circled is the Turn Signal/Hazards Flasher.
Thanks for the help guys.
