Tire Size and Wheel Offset Calculators
    Here's a helpful site for those who want to figure out the correct tire sizes to get when buying bigger wheels/lower profile tires.
    Miata.net Tire Size Calculator:
    Clint/1999 "Sport20"
    Additional Calculators
    Tire Size Calculators:
    Wheel Offset Calculators:
      I've got a couple more that are handy as well..
      This one is cool, it even does effective gearing based on diameter changes.
      not too shabby either (basically the same as the 1010 one,but without the fancy graphics)
      1010 again
      --sarge
        Here's my favorite:
        http://www.rims-n-tires.com/rt_specs.jsp?postId=906
