1st. -> we have to fin suitable car and angle to make side vent
2nd. -> select the part that you want to become side vent, then c/p
3rd.. -> use image/adjustments/brightnes&contrast, tu little bit shadow selection, and use burn tool to shadow upper side and air intake like on the picture
4th. -> use eraser, but lower their opacity, and use it with blur so you can erase right part of side vent, to become smooth edges
5th. -> now select the edge of side vent, like on the picture, and use brush to paint the selection, colour you have to pick is brighter colour, you have to find colour on car from upper side of car, roof, or below the side windows
6th. -> the result of brushing should look like this
7th. -> inside the vent, make selection, and use same colour that you use to fill up selection on 5th & 6th , when you do that, use burn tool to adjust it
8th. -> result of doing that should look like this, also you can put a little bit blur on upper side of selection
9th. -> and the finally, you have to c/p part of the door that is inside the vent, select it, and c/p it to the right, not much, it depends how much is deep side vent
10th. -> result of it
11th. -> now you just have to connect c/p part with original door
FINAL
FINAL
