B8: piston to head clearance
    Anyone have a factory service manual, or can actually take measurements of the piston crown height vs. the head with a compressed oem headgasket?
    Thanks
    -93 MR2, 129 ES
    ClubProtege.com Tech Articles
    Originally posted by WTF
    I found the piston-to-cylinder clearance, not sure if that's what you want. Per 1992 FSM
    Standard 0.039mm-0.052mm
    Maximum 0.15mm
    Edit: Or would that be the distance between the piston and cylinder walls? Sorry, I don't know all these terms... haven't taken apart an engine yet
    2006 Mazda 3 hatchback manual
      no problem, thanks Charles!
      I emailed Vaughn, and he replied back between .080 and .100.
      if we have the time, we're gonna shave the head .040 to bump compression and reduce the squish height in order to make it more knock resistant.
      -93 MR2, 129 ES
