Lateral link bushings ??
    I could have sworn that I found an Australian spec part on a TX3 that was the same as the FWD BG/Escort...and was carried by Superpro.
    It was something like 7 years ago. Did I ever post all my research?? It's only a frag of of memory for me.
    Drew
    '95 EGT 1.8
    T
    '93 ELX 1.9 SC
    '91 ELX 1.9
      Found it. http://www.wihandyman.com/forum/show...light=SPF1786K
      Drew
      '95 EGT 1.8
      T
      '93 ELX 1.9 SC
      '91 ELX 1.9
        Here is my email to SuperPro.
        This is the modified old list that I never pulled the trigger on purchasing back in 2008. I went over all of the dimensions and specs today (Nov 2015) from the CAD drawings I got from SuperPro (in 2008).
        This will be the list needed for a FWD Pro/323/Escort (non-MX3 TTL's) with all the 31.6mm dia bushings. The extra washers are so people don't need to have that spacer machined (you need 10.6 of the 1.6mm washers to make up the difference...so 11 extra it is...each side)
        ...or have a spacer machined (17mm L x 22-to-36mm OD x 14.3mm ID) and make wind chimes out of the extra 22 washers.
        Hi,
        I am looking to order a set of bushings and parts in a custom kit. It is for a full rear control arm set for a Canadian '94 Ford Escort (your Lasers) /Protege/323.
        Here is the list that I need:
        1994 Ford Escort GT (FWD)
        SPF2457 (x6) Bush
        SPF2457T (x6)
        SPF1220T (x2)
        SPF2891 (x2) Bush
        SPF1576W (x30/Thirty)
        Is there anyone in Canada that can deal with this order? Or should I deal directly with you?
        Thanks a lot
        -Drew Skuce
        Drew
        '95 EGT 1.8
        T
        '93 ELX 1.9 SC
        '91 ELX 1.9
