Hey Everyone,
I have a 91 EGT and a GTX swap has been in the plans (and works) for a while. I wanted to ask the people that have done the swap a couple of essential questions before I order the motor.
1. How difficult was it to re-wire a GT harness in order to run the GTX computer without the car being in limp mode ... if it wasn't too bad, was it easy to locate a knock sensor/control box; or did you somehow trick the computer into thinking there was one on there? Are there any other additional sensors on the GTX that are not found on the GT (aside from the knock sensor)
2. Have you guys had any experience with JDM source in Calgary Canada (http://www.jdmsource.ca/) or with J-Spec auto sports from Quebec Canada (http://www.jspecauto.com/default.aspx)
3. Did anyone use the AWD clutch in the FWD transmission with good results?
Thanks a lot in advance,
Alex
Alex
