Installed Suvlights Heavy Duty Headlight Wiring Harness
    After reading this thread, I've got a little something to add.
    Regarding the Diode addition in parallel with the coil, Hella makes a relay like that if you don't want to do it yourself:
    Only 8 bucks from Rallylights.com
    It's listed as a 20/40A unit, I'm not sure exactly how the dual current rating is found.
    --sarge
      Nice find. It makes the whole process of adding a diode much simpler.
