need turbo kit 1999 1.5 vvt mazda japan spec
    have 1999 1.5 right hd.what would be the best turbo kit for this little motor HP stock 130.
    island-p5
    i don't any turbo kits for the that motor at all. the reason why i wouldn't swap that motor in is the lak of aftermarket support or i would in a heartbeat
    but i guess it's not different from the 1.6L heh
    do it like the rest of us. do it custom and post what kind of result you got out of it.
    1987 Rx7 TurboII (Stripped and Crush R.I.P )
    1987 Rx7 Sport (Street port Rebuild almost done.)
    2006 Infiniti G35 Coupe w/ sports package
      SWEET! your the first one i have seen that actualy has this engine in their car, post up some pics of the motor, btw welcome! your car looks sweet!
      .....HELLO MY NAME IS BEN...
      186.08whp
      225.94wtq
      torque monster!!!!
      dyno graph 8-10-and 12psi
      blahblahblahblahblahblah
        looks good ... welcome to the boards ... sorry i cant help you out with the turbo kit though.
          HiBoost kit!! (its the only one made)
          The 1.5 and 1.6 are basicly the same engine but the 1.6 is the stroked version. Everything else is interchangable. Speaking of which send some of thouse vvt heads over this way.
          Alternetvly wagner makes an exhaust manifold that should work. I would use that and a fuel pressure regulator, that is unless someone knows how to make the haltech control vvt.
            Nice! Post up some engine pics. That's the first Protege I've seen with a 7500rpm redline. *drool*
            Clint/1999 "Sport20"
              1.5 vvt
              This is me babe 1999 j-spec p5 1500cc vvt motor,5-speed, 15s wheels, 2in pipe, mazdaspeed muffler,homemade coldair intake,[pvc pipe]centerforce dual friction clutch,jdm coilovers. someone help me set this little gal up.also has the jdm radio [screen tape tv in one]. :
              island-p5
                looks alot like the 1.6 so if the mani is the same then yeah the hiboost kit would work, and rip too!!!!!
                186.08whp
                225.94wtq
                torque monster!!!!
                  by the way here is the thread with the highboost kit.
                  186.08whp
                  225.94wtq
                  torque monster!!!!
                    How about a picture of your cold air intake. Does it work any good? I saw an artical on autospeed where the guy used a 5" pvc pipe to make one it was massive, but made good power.
                    If you do go highboost be sure to find away to control the vvt or youll loose your really high redline. If the haltech cant handel it youll need to come up with a standalone solution. If you go to the miata boards they can help you out with that. its a pretty strait foward design as rpm increase the soloniod pressure should also increase.
                      I need to take some pic,because i have since change the wheels and painted the head lights black,i would show the intake soon,it does make good power,but better is the sound when the vvt kicks in at around 2500-3500 rpm,i have to sa thanks for the advice thanks again. please see this site-motorsportsgrenada.com thats where we have fun on weekends, its an old airport.
                      island-p5
                        pics of 1.5vvt japan spec
                        this is the motor and the coldair intake,and more.
                        island-p5
                          dont look too bad, i would have apinted it a diffrent color, but other then that it looks good.
                          186.08whp
                          225.94wtq
                          torque monster!!!!
                            Very nice whats the deal with the stock snorkel? Looks? I noticed you too have the dreaded gray interior I feel your pain man, at least its still better then the beige.
                            Is the front lip stock or if not who makes it?
                            You can order some black clear corners from pcp it would look really good with the painted headlights.
                              maybe i will swap that motor in. i'm getting more and more interested in this 1.5 everyday since this dude posted. let me go find corksports qoute from 2 years ago
