differences between 94 Protege Motor & 94 Miata Motor.
    I need to know the differences between both.
    Both are BP DOHC.
    but it uses the same head and block ?
    same cams ? same valves sizes ? same cam gears ?
    same throttle body ? same intake manifold ? same injectors ?
    i know that uses the same piston but difference compression.
    have the same stroke ? same piston rods ?
    about the tranny..protege is front wheel drive and miata rear wheel drive..
    have the same flywheel ? can use the same clutch kit ??
    Thanks.
    different heads, same block, different pistons, VERY different tranny's. here check out this site.
    Discover the latest breaking news in the U.S. and around the world — politics, weather, entertainment, lifestyle, finance, sports and much more.
    Originally posted by goldstar
    A Protege driver named Brock
    So his engine he goosed
    With much too much boost,
