Inside of car smells like gas
    Hey, the cabin of my car smells like gas, and It's been so for the past 5-6 days. Any clue? I didn't like spill any inside. I've had ventiliation since then, I've had windows open, heat on, etc. and the smell is still there.
    1994 DX SOHC Auto (Tropical Emerald Metallic)
    Panasonic CQ-C8400 HU
    eDi 6500 Components
    Arc Audio KAR 200.2
    Elemental Designs NINe.1 Amp (1000W@2 ohm)
    eD 16ov2 IB
    eDead
    Autopage Security System + Power locks!!(KEYLESS ENTRY!)
    cardomain
    might wanna look under your rear seat for any leaks around your fuel pump.... the seat is easy to remove; just pop loose the fasteners along the underneath of the front edge of the seat and it should come right out.
    Original owner: 1991 Protege LX (now w/SOHC) and a few more BG's ....
      Yeah, I smelled around my back seat, and it wasn't strong around there at all...
      eDi 6500 Components
      Arc Audio KAR 200.2
      eD 16ov2 IB
      eDead
      cardomain
        STOP EATING CHILLI CHEESE FRIES AND BEAN BURRITOS
        might be a missing firewall grommet and it's entering the cabin that way.
          I had a Nissan that smelled like that... turned out it was actually an exhaust leak
            Check the fuel filter connections...yea it's a ****ing bitch to get to it , but that's what it is.
            NOW WITH SPINNER HUB CAPS
              if it don't smell under the seat, smell under the passenger & drivers footwell area. If it smells then you might have a leak under teh hood. Pop it up and check for leaks around the fuel filter hose & lines.
              I had this problem on my festiva. Turned out I overfilled the tank filler neck & it was smelling up the interior b/c the gasket around the filler neck was leakyish.
              93' Noble Green MX-ZE (sold )
                damn ****, you're lucky your car hasnt burst into flames yet
                  i've got a how-to for the fuel filter if you need it.
                  '12 Focus SE hatch
                  '05 Saab 9-3 turbo (sold)
                  '90 Mazda 323 GT (sold)
                  '04 Mazda Tribute (sold)
                  '92 Mazda Protege LX (sold)
                  '91 Honda Prelude (totalled)
                  '91 Honda CRX SI (sold)
                    lol pull the motor out its easier to get to that way
                    More Information
                      i had to slam on my brakes and spilt gas in my trunk and it soaked through my backseat...it stunk. I got a whole new backseat for $20 they came out cleaner than what was there (before the spill). I had to replace the seatbelts too. Febreeeeeze. It was fun. With all the static my car creates, I'm suprised I didn't die. It was fun.
                      ClubProtege
                        don't know if you have discovered the source of your problem, but if not I got something close to your problem. Just try next time you put gas in your car not to full it. It may be like mine that as a hole right at the beginning of where you put gas. To check just take out the wheel and the little plastic cover then you'll see if there is a hole there. Hope it will help you !
