Polyurethane replacement bushings list.
    This is an informative thread on polyurethane replacement bushings.
    *UPDATED WITH NEW DISTRIBUTER & PRICES 01/17/08*
    1. Whats available:
    Front Lower Control Arm bushings (2 each side [1 front 1 rear]
    "available through Energy Suspension, Superpro, & Noltec Suspension as well as a few other random availabilites."
    E.S. part number: 4-3152 (*$25.00)
    Superpro is a completely different world as far as the bushings available.
    they have different durometers(hardness) within +/- 3 duro available as well as offset sleeves to change suspension characteristics.
    Superpro part numbers:
    FRONT LCA BUSHING (oilpan side)
    SPF0952-80k Comfort-80 duro "38 mm outer diameter bushing" -$40
    SPF0952-90k Sport-90 duro "38 mm outer diameter bushing" -$40
    REAR LCA BUSHING
    SPF0953-70k Standard alignment Comfort-70 duro "35.5 mm outer diameter bushing" -$38
    SPF0953-80K Standard alignment Sport-80 duro "35.5 mm outer diameter bushing" -$38
    SPF1633K Single offset "Shell part" passenger side increase -$90
    SPF1634k Double offset-80 duro "Shell part" passenger/driver side CASTER increase/decrease -$91
    SPF2415K Standard alignment (shell part) "46mm outer diameter bushing" -$53
    SPF2416K Single offset (shell part) "46mm outer diameter bushing" -$53
    SPF2417K Double offset (shell part) "46mm outer diameter bushing" -$53
    Noltec part numbers:
    Front LCA bushing: N-51262
    REAR LCA BUSHING
    Rear LCA bushing: N-51263
    SWAY BAR ENDLINKS/FRAME MOUNTS
    E.S. part numbers:
    ENDLINKS
    ZX2 swaybar endlinks- 4-5169 (*$22.00)
    Regular BG models- 4-5140 3/4" (*$24.00)
    FRAME MOUNTS BUSHINGS
    ZX2 swaybar 25mm- 4-5168 (*$7.00)
    Regular BG models- 4-5139 3/4" (*$24.00)
    Regular BG models- 4-5141 15/16" (*$24.00)
    Superpro part number:
    ENDLINKS
    SPF0903K- swaybar endlink -$19
    Front- SPF0908-_ _K "insert measured bar diameter 19,20,21.5mm available"- $16
    Rear- SPF1406-_ _K "insert measured bar diameter 20mm available"- $16
    ENDLINKS
    Swaybar endlinks front or rear: N-21169
    Swaybar frame mount (20mm): N-21536
    REAR TRAILING ARM BUSHINGS
    E.S. part number: 4-7123 (*$30.00)
    SPF0907K front bushing-80 duro "40mm outer diameter bushing" -$42
    SPF2744K rear bushing-80 duro "44mm outer diameter bushing" -$53
    Noltec part number: N-61764
    REAR (TTL SYSTEM) LATERAL LINK BUSHINGS (SEE THREAD HERE)-----> Lateral link bushings thread
    E.S. part number: NOT IN PRODUCTION
    Superpro part numbers: NOW AVAILABLE
    SPECIFIC FITMENT TO MX3 LINKS (which add +15mm track each side) 36mm O.D.
    WILL NOT FIT EGT/Protege Links without machining
    SPF1786K-$88 lateral arm front inner bushing to chassis 4-bushings
    SPF1787K-$98 lateral arm rear outer bushing to stub axel 4- bushings
    NOLTEC SUSPENSION
    Noltec part number: N-61753
    I have personally installed these bushings and i can attest to it being a large pain in the ass without proper tools.
    be prepared for 1 full day's downtime when replacing these bushings given proper tools.
    Also note that Noltec does not cut grease grooves into the bushings to lubricate the sleeve as does energy suspension and superpro.
    I advise taking a sharp knife and a torch and melting 8 grooves into the bushings before installing.
    This prevents binding and squeeking and prolongs the time
    needed between regrease intervals.
    __________________________________________________ _______________
    As for energy suspension products... they can be purchased cheapest through
    www.suspension.com all energy suspension part number costs listed are actuall cost through this website. and are labeled as (*$??.??)
    As for Superpro products they are originally an overseas company from australia.
    Australian assembled and tested lift kits. Backed by a 3 year, 60,000km warranty.
    However Superpro has found a new distributer in the USA(Tein)- prices are raised & ordering has now become much more complicated.
    contact information goes as follows:
    http://www.tein.com/dealer_list/usa.html For online shopping select your state & find a distributer
    As for Noltec suspension products they are originally an overseas company from australia as well.
    All products Must be ordered from them so far as i have not found a US shores distributer.
    Prices vary & air mail shipping costs must be added to the final total.
    * NOTE THAT NOLTEC SUSPENSION OFFERS MORE PRODUCTS THEN LISTED HERE IF INTERESTED CHECK THE FOLLOWING LINK *
    here is a direct link to the BG bushings product listings that they offer.
    Noltec BG bushings
    contact information as follows:
    Telephone number (011) 612-9980-9777 *mind you this is a direct call to australia*
    Noltec homepage
    Address:
    Noltec Suspension
    3/14 Duffy Avenue
    Thornleigh NSW 2120
    AUSTRALIA
    P.S. Noltec bushings come in a sweet blue color but may need grooves cut for grease prior to install.
    2. Reasons for replacing rubber component bushings with polyurethane compound bushings.
    first off... rubber can become worn out over the years & chances are by this time they are worn out.
    Rubber compounds do not take well to weathering or irritants.... such as snow, salt rain, heat, dirt/grime, grease, oil
    worn rubber bushings effect alignment and stability of the car.
    As well as reducing the cars ability to properly navigate the road even given the harshest circumstances.
    worn rubber bushings effect directly the steering of the vehicle as well.
    Symptoms of worn bushings include but are not limited to.
    Improper alignment.
    odd steering feel.
    misc. noises/clunks
    worn/rotted/non existant bushings
    uncomfortable ride quality.
    lack of stability in movements of the car.
    OLD CAR FEEL(sloppy all over)
    inprecision of the vehicles driving characteristics.
    >>>>>>>>>>>>>>>Pictures as following:
    Lower control arms (with E.S. bushings)
    in need of trailing arm bushing pictures
    in need of rear lateral link bushing pictures
    contact me if you have pictures.
    I hope this serves well as a good basis for those seeking poly urethane alternatives to the worn stock bushings.
    Nice job , very useful for me, because I am going to buy everything what is available.
      good job dude!
      i got everything for about $80 shipped (minus the rear TTL's)
        sweat post bro
          thank you thank you... takes a bow
            very nice.
              Hi bpt323 , I tried how bushings fit in front control arm, but I am confused, because the bushing in FCA is hard to push in by hand without sleeve (i think this is OK). But second one I can push in bracket with sleeve by hand!!!!!.
              As You can see, I leaved old shell in(with some pieces of old bushing), but there is small freeplay
              So what is wrong?????
                exactly what bushings did you use? and from whom??? i can't say for sure if the GTX bushings are the same or not.... but i do not see why they would be. mazda reused alot of parts across the model ranges. first off i say clean that out properly was the bushing in that end sleeved? er... i think they are all sleeved... did you press the sleeve out?.... im really not exactly sure what to tell ya. seeing as your overseas im assuming you went with superpro?
                  I have Energy susp. kit 4. 3152G,
                  I drilled few holes to old rubber, than I pushed sleeve away. And result of this You can see on the picture
                  Solution is to make shell which will fill this space, but I can't understand why is it?? Different dimension on euro models??
                    are you sure you didn't mix the 2 bushings up from the kit and try putting the wrong one in the wrong place? this is the first time i've heard of any problems
                      For bracket is bushing with bigger hole in the sleeve, right????
                        take the front bushing bolt... and slide it through the sleeve it fits most tight in. then match that with the correct bushing. the other one is the rear. if the sleeves fit perfect in each (i dont' think they do) then come back again and we'll get it figured out
                        Do you have AOL IM? or Yahoo IM??
                          I do it right, I am 100 perc. sure
                          I have only ICQ.
                            its odd then. im not exactly sure what to tell you.... thats pretty crazy tho... do you have AWD??? or FWD?
                              I have 323 F BG (Astina), it is FWD.
