Results 1 to 9 of 9
Thread: P1195- EGR boost Sensor
  1. #1
    Registered User
    Join Date
    Feb 2005
    Posts
    1
    Feedback Score
    0
    The dreaded CEL came on my 98 Protege and I took it to a local auto shop. The person diagnosed it as the P1195 code. He said something about the EGR boost sensor so I have a few questions..
    1) What is the EGR boost sensor..is the same as an oxygen sensor??
    2) He said it'll cost around $500 to replace it, do you think he is scamming?
    Anybody ever had a similar problem??
    Also an ideas on how to reset the CEL??
    Thanks a ton!!
  2. #2
    Old Noob Kelly's Avatar
    Join Date
    Dec 2003
    Location
    St. Louis
    Posts
    2,233
    Feedback Score
    0
    http://www.clubprotege.com/forum/sho...R+boost+sensor
    I did a search for Egr boost Sensor and found 5 threads discussing it.
    Welcome!!
    Todays thought of the day:
    Mitch Hedberg
  3. #3
    Registered User beetle_orange's Avatar
    Join Date
    May 2004
    Location
    North Aurora, IL
    Posts
    1,489
    Feedback Score
    3 (100%)
    Mods:
  4. #4
    9296D21b14
    Join Date
    Feb 2005
    Location
    SE Louisiana
    Posts
    7
    Feedback Score
    0
    EGR port cleaning ?
    I have read as many posts as I can find on this code. 98 Pro 1.5, auto, 193k, no driveability issues. I've cleaned the TB w/out removing it, checked all vacuum hoses, replaced PCV, wires, plugs, AF, fixed an intake tube leak, Techron fuel cleaner treatment. I tried to insert a small drill bit into the intake plenum vacuum hose fitting that leads from the plenum to the boost sensor from the outside as recommended to clean any carbon block but it seemed to hit something solid about 3/4" or so in. Should the drill bit be able to go further than that? Is that the carbon that needs to be cleared? If I push the bit further in will it be hitting something it shouldn't? Will it hurt to spray TB cleaner into that fitting? I plan on eventually removing the TB and EGR valve for cleaning but wanted advice on just clearing that hose fitting first to see if it would restore proper vacuum to the boost sensor and clear the code for good. Haynes manual on order but wanted some advice from this forum. If all of this doesn't work, I'll get the sensor itself tested but dealer price on a new boost sensor is $400+! This forum has been a big help. Thanks in advance.
  5. #5
    Registered User OCD-SPEED's Avatar
    Join Date
    Oct 2003
    Posts
    998
    Feedback Score
    -1 (0%)
    500 is insanity for just a boost sensor! Its no bigger than a quarter and literally takes 2 seconds to install. Go to a junkyard find your model protege and pocket that ****!
  6. #6
    Registered User
    Join Date
    Oct 2011
    Location
    Lebanon TN
    Posts
    4
    Feedback Score
    0
    i just paid $30 for a boost sensor on ebay!!!
  7. #7
    my name is a verb now Turpro's Avatar
    Join Date
    Jan 2004
    Location
    Cincinnati suburb Ohio
    Posts
    17,189
    Feedback Score
    73 (100%)
    You just bumped a 6 yrold thread
    Quote Originally Posted by jay View Post
  8. #8
    Registered User
    Join Date
    Aug 2014
    Location
    Athens, AL
    Posts
    7
    Feedback Score
    0
    Is there anyway to test this sensor? I just had my intake off and cleaned out all the EGR passages and the EGR valve and put new seals on the injectors and now I am getting the P1195 code. Never even touched it although there is a vacuum line to it.
  9. #9
    I'm on a boat. Kitty's Avatar
    Join Date
    May 2006
    Location
    Oahu, HI/ The ocean
    Posts
    3,153
    Feedback Score
    17 (100%)
    Quote Originally Posted by dirtbikedad View Post
    Name:  egr boost sensor test.png
    The SST is basically 12volts switched. You can do it with a 9v battery.
    I take paypal for consultations on decade old threads.
    mtthwhllnd at the gmail
    Beater=/= Sleeper
    Quote Originally Posted by kozzman555 View Post
    Quote Originally Posted by HopelessCow View Post
Thread Information
Users Browsing this Thread
Similar Threads
  1. EGR Boost Sensor
    By 96ProtogeOwner in forum Engine/Drivetrain - BHA Chassis
    Last Post: 10-29-2011, 10:53 PM
  2. So I had a CEL (P1195) today...
    By smokstac in forum General Discussion - BHA Chassis
    Last Post: 07-22-2011, 10:41 PM
  3. I need help with P1195
    By ptabor in forum General Discussion - BHA Chassis
    Last Post: 03-27-2005, 09:08 PM
  4. P1195 Need Help!
    By mango02 in forum General Discussion - BHA Chassis
    Last Post: 12-02-2004, 10:16 PM
  5. EGR Valve Position Sensor Open??????
    By heatsink in forum Engine/Drivetrain - BHA Chassis
    Last Post: 11-08-2004, 01:46 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
