A/C fuse keeps blowing
    Hi,
    I popped the hood the other day and realized that the a/c fuse in the engine bay was blown. i replaced the fuse with a new one and it worked fine for about 10 minutes then it blew again. My fuse cover does not have a sticker, is 20amp the proper rating? Also what could cause the fuse to go? Everything seems fine until the fuse goes...
    Thanks.
    J
    1990 Turbo Miata
    1990 Miata - a few mods
    2002 Subaru WRX
    2002 Protege 5
    2000 CBR929RR 150Whp
    A short somewhere in that circuit, including a component itself, would cause that kind of problem. Those are the worst kinds of problems to diagnose. If I can only remember to check for you to see if the fuse rating is too low. However, it didn't blow before with that fuse rating so there's probably something wrong like a short.
