I have a '91 Protege DX and I really want power windows and locks. I found a wrecked '93-'94 LX at a junkyard with a fully intact interior. Instead of swapping the inside door trim onto my existing doors, would it be possible to swap the doors onto my car? Also, would the rest of the interior (dash, seats) fit? Any help is greatly appreciated.
Interior swap
I haven't even bought the wrecked car yet. I just needed to know how easily this stuff would fit. All I want to know is if the doors on a 93-94 model will fit a 91 model. If so, then I have what I need. I just need to buy the car.Last edited by Killswitch; 06-20-2005, 02:20 PM.
im not sure of all the years but my 323 has the plug already terminated in the door sil besides that its like 2-3 relays and a fuse!(well besides the actual door swap)"Discontent is the first necessity of progress."
Originally posted by viper_70791 to 94 are still the same cars just interior styling got better
ok, instead of making 600 different chassis harnesse the made 2-3 (2 door, 4 door ect)
so the wiring for the fuse box and all the under the dash stuff(minus the relays and fuse are there, if you pull the boot off of the door sil harness and look at the plug, all the wires are there,(kinda plug and play) hope this helps"Discontent is the first necessity of progress."
Originally posted by KillswitchNot true. I had to find a taillight replacement for my '91 and tried one off a '94 and it didn't fit. The body styles from 91 to 94 were altered just slightly. The interiors are all the same, but the exterior was changed just a tiny bit.
I swapped power windows, mirrors, and cruise in about 4 hours, swapping doors seams like it would be a pain, aligning it once installed, pulling the fender off, but it might be easier
LX Steps: (roll all the windows down before disconnecting the driverside windows switch)
1st get the power windows half way down, makes unbolting the glass much easier
take the glass out, unbolt the motor and slide, unplug it, then pull it out
next you need to remove the wire harness, just look at it, you can figure it out, it unplugs under the kick panel
take the door panel, wire harness, and motor to your DX
(DX and LX Glass are the same, my DX glass is tinted so I reused it, no Mods)
DX Steps:
pull the door panel
crank the window down to loosen the bolts that hold the glass
remove the glass, then the manual slide
remove the wire harness the same as before on the LX
then reinstall in reverse order
Driverside windows switch has to be connected before any windows will work
Good Luck, dapro94 Protege DX SOHC 1.8l 5 Speed
(DaPro)
its better to wait and save then to waste money on crap to get you by....
