Any welders here?
    Any welders here?
    I forget where since it was a long time ago, but I seem to recall reading somewhere that it was possible to weld stainless steel without a tig welder, true??
    If so what need to be done? I've got access to an arc welder can it be done with one of those, or does it need to be done with a mig using stainless wire?
    Anything else you can suggest would be appreciated as well.
    Thanks.
    Ryan The middle child is always ignored
    BP powered 97LX Touring Edition
    Vibrant strut tower brace, KVR front brake pads, Tungsram Megalicht H4 headlight bulbs, Phillips Halogen H3 foglight bulbs.... 91 GT rims w/ 195 60 14 Yokohomo Mirada GTX sport
    I do mine with a mig and SS wire... since I dont have a gas setup (reccomended for ideal welds) I found some flux cored SS wire on ebay for about 35 bux for a 2lb spool shipped (locally shops wanted 85 for the same thing!)
    It works well, but I will probably buy a set of bottles for a gas setup eventually.
    I cant find the ebay store that I got my wire from, but heres one thats similar:
    you might email the seller to see if its flux cored so you wont have to use gas.
