Originally posted by bpt323
View Post
GTX-GTR and General Turbo information
Originally posted by turpro View Posthmm. sounds like the one your sending me.
Originally posted by bpt323 View Postthe three times i've shipped turbos out they've gone to turbo city.
twice for rebuilds & one time to find out my VJ20 was ****ed.
$200 labor & i paid $60 for a rebuild kit from them. cleaning & paint is like $35
I think that info is needed here!
Originally posted by Lex View PostGarrett GT/VJ14 - Corksport lists this on their site... I've heard of people using these in Australia and NZ. And yes, I'm 99.9% sure that a GT25/28 will not bolt up to a stock manifold.
Alright, well I just bought an 88 mazda 323 gtx. Only "mod" done to it is a cold air intake, but the ECU has been reprogrammed for 16psi of boost and 8k redline (although I will never take it to 8k, highest maybe 7k). It does have the stock VJ-14 on it and I know that 16psi is pretty much its limits but I was wondering if you knew anything about the VJ-14 upgrade from corksport? The VJ-14 spools VERY quickly and will hold 16 easily all the way to redline, but I was wondering how big of a difference the VJ-14 upgrade from corksport made? It says it has a dual ball bearing center section with T25 cartridge, and T-3 style compressor wheel and I will have to use the stock exhaust housing on the current turbo. Just curious if you knew any gains from this turbo? Spool faster? Can handle more boost? etc etc.
I am also currently running the stock downpipe which is pretty small for 16psi, you can feel it sometimes. So I'm thinking the VJ-14 upgrade will be very worth it with just a bigger downpipe and the bigger core intercooler upgrade from corksport...
Here are 2 links I found not a long time ago.
It's a guide to draw a compressor map from the maps that IHI has in the site.
The other one is how to read it.
The compressor map is for a vj-23
http://toymods.net/forums/showthread.php?t=17487
http://toymods.net/forums/showthread.php?t=17687
One thing is not covered in that how to section is modding the coolant lines. I think I ended up using one stock bpt hardline and one suby line. I need better fittings cause I get small leaks after a long hard drive.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
It was I who wanted that info Care to measure the stock BP rod again for comparison? b6t one too if you have one---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I should mention that number was with stock bolts and nuts attached. The NA BP ones are 562grams each with bolts and nuts attached. B6t rods are 580 grams.
Here are also some more weights of aftermarket rods:
Crower rods 543grams
Pauter rods 493 grams
Carillo rods 442 grams
Don't know which model these are and they are pulled from a site (http://www.quithel.co.uk/). I am guessing the Carillos are the A beams
The site mentioned has some great info.Last edited by Lex; 06-01-2007, 12:28 AM.
bad link^..... you sure the GTR rods aren't heavily they are notibly larger & thicker, 30grams isn't much---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Postbad link^..... you sure the GTR rods aren't heavily they are notibly larger & thicker, 30grams isn't much
Those two first links at the beginning of this thread are dead... dangit.
AHHH... found the new website... please update:
http://www.not2fast.com/turbo/glossary/turbo_calc.shtmlLast edited by Shades; 12-25-2007, 12:16 PM.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
