I have been doing a bunch of research concerning different types of lightweight flywheels and on the miata forum many have put a 1.6 clutch and flywheel on the 1.8 and love it... now i know their trans are different but is it possible to do that on the bp? i have a mx3 that i'm putting a bp in and i'm still going back and forth on the drive train and i want to look at all my options including awd vs fwd so i was curious if i can use a 1.6L clutch and flywheel on the f series FWD trans? or will that trans only accept the 1.8L clutch?
1.6 flywheel and clutch on a 1.8?
In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
The ProjectMx build thread
MyCardomain[/SIZE]
"Shut up, at least the bunnies are on fire!"Tags: None
which clutch is it? i'm assuming the flywheel is the same that the miata uses?In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
Originally posted by projectmxwhich clutch is it? i'm assuming the flywheel is the same that the miata uses?"Discontent is the first necessity of progress."
Originally posted by D323yes you can use 1.6L stuff in the 1.8L tranny.
The otherway around DOES NOT work, as the F series(1.6L) is slightly smaller than the G series (1.8L)
just get the correct flywheel to go with the correct clutch and you should be fine.
Exactamungo! The G-type will fit on a 1.6 but the G-type clutch and flywheel will not. and vise versa.www.gopostal.com
If NISMO stands for NISsan MOtorsports . . . . Does HOMO stand for HOnda MOtorsports ?
Originally posted by TwinCam16Does this mean that the miata clutch cannot work for the f-series gearbox?
Not as far as I can tell. I havn't tried it but I know someone who has with little success.www.gopostal.com
The splines are different
and easy way to tell is look at the part number for the Pilot tool"Discontent is the first necessity of progress."
