Click click when turning?!
    Uhh to begin with its with my 89 (beater) tracer/323. Sure its not a BG but one year off damnit! Anywho. As of a few days ago i heard a clicking when turning left and accelerating and i thought it was coming from the back but today noticed its from the front when i turned my head and heard it clearer. It sounds like the usual axle click click but i've never had one go on me so i'm not 100% sure. Also near my house it seemed to now do it when turning right as well but not as loud. WTF did both decide to go within a few days of each other?!
    PS: I did replace the boots last year after they broke with those quick boot dealies but eh i doubt it matters now. Car has 145k as of yesterday and i think factory axles!
    PPS: Forgot to mention the original louder when turning left clicking sounds like its coming from the passengers side.
    Have you checked for torn CV boots yet?
      Not recently no. But assuming they are torn they (axles) are dead anyway no?!
        A torn CV boot doesnt mean that your whole axel is junk. The only thing that could fail if you have a torn CV boot is your Constant Velocity joint. I wouldn't assume that a CV joint needs to be replaced just because the boot is torn. If you catch it in time, you can save the CV joint and just replace the boot. But if your CV joint is clicking, then it's too late, and you need a new CV joint.
          My thoughts as well.
            Yeah thats what i thought. I already "saved" it before on each side when they tore. Thing is which side is it? I assume the P/S but not 100% sure....
              Well, I'd start by taking a look at the boots. Just because the noise happens when you turn to the left doesn't mean that the left CV joint has failed. When you turn to the right, the left CV joint still moves, and vice versa. If you hear the noise coming from the right side, then your right CV joint is junk. Don't forget to check out your front end.....b.j.'s, t.r.e.'s, l.c.a.b.'s, w.b.'s.....ect.
                My whole front end is new on the car minus the LCA bushings, etc. Ball joints, tie rods both inner and outer, bearings, seals on hub, etc. are all new within the last 12 months! This was my daily/ONLY driver before i got the EGT so i got alittle ahead of myself! =D Either way i just got both axles non reman from ebay for $120 with NO core charge can't beat that! And yes the right side clicks when i turn left! But like i also said it seems to click when going right too when i was close to being back home so eh. $120 for the sake of the little sanity i have = the win! =D Especially when most places charge $120-140 including core for just one and are remans! Also the boots were replaced about hmm 8-10k ago so basicly the axle is shot period. Thanks guys! Wish me luck with that 100+ ft lb axle bolt and probably c-clip in the tranny!
                  Cool man.....way to have an optimistic outlook . have fun!
                    If you wanna call it that! :microwave
                      UPDATE.... Finally got a chance to look at the car today even though my axles didn't come yet ( ) and it seems that one of little bolts that was holding the "quick boot" on broke on one end on the actual rubber piece and seperated the boot just enough to make the grease go byebye. So i bootlegged it back together for now after filling with grease and the ticking seems to be gone so hopefully this will work for a month or two before it gets warmer and i can just put on the new axles!
                        Good to hear man. Sounds like a real canadian connection tho.
