To folks with GTX/GTR cams. (BP26)
    PS. Welcome to the club.
    Ryan
      thx!
        At the end, just take the exhaust cam of the b26, an put it on the intake, as the intake cam, and thats it?
        Just that...
          Just that...
          yea but you have to rotate cams 180 degrees... blah blah blah
          it's really confusing... i wouldn't bother doing it, but you can if you want
            It is not that easy then
              its easy as hell, jamacian your just lazy
                  seriously.. i read somewhere, they said you have to turn something 180*... something 2 clicks and another thing at 10*, another click here, one there
                  sounds confusing to me... even the dude jrally is having trouble
                  if it is indeed easy... i'll do within this month
                    the instructions are @ the top on how it needs to be positioned
                      do u need adjustable cam gears to do all this or no?
                      BF 323 wagon, 360whp(dyno dynamics) 12.20@127mph
                        yes, you'll need one at least for the intake cam if you have another BP26 exhaust cam to run... if you are going to run an NA exhaust cam you'll need one on there too.
                        -jon
                          technically you could do this one easier then its NA version counterpart.
                          however i do reccomend @ least 1 adjsutable gear on the exhaust for this one
                            you mean on the intake cam?
                              no jon not with this version the turbo version is opposite of the NA one.
                                ah i see now. 2 teeth advanced puts you at the same overlap as a stock bp26 setup. now what if you actually had a bp26 exhaust cam, instead of an NA cam retarded 6 degrees?
