wheres my starter interlock switch?
    where is the starter interlock switch located?
    Do you have an auto or a 5 spd?
    On a 5 spd it's on your clutch pedal. On an auto it's integrated in the gear selector.
      I've wondered about that. There must be some way to disable the starter interlock while leaving the clutch switch able to break cruise control.
      Of course I have no idea how or where to do that, but if anyone else has already done it...
      1990 Protege 4WD
      1 3 5
      2 4 R
        Yes. There are two different switches on the clutch pedal. The smaller one is for the cruise control cutout, and the larger one is the starter interlock. Just unplug it and jump it. I've been thinking about doing this myself.
