Mileage on your 1st generation
    Since there is a 2nd generation poll, how about a 1st generation poll?
    I'm at 46,6xxx on my 1994 Protege DX, on chasis and original engine. No problems except for my dome light fuse that I don't feel like replacing.
    444
    50k or less
    3.60%
    16
    60k-75k
    2.70%
    12
    75k-95k
    6.08%
    27
    95k-110k
    4.28%
    19
    110k-120k
    4.95%
    22
    120k-130k
    6.08%
    27
    130k-145k
    12.16%
    54
    145k-160k
    10.14%
    45
    160k-185k
    13.06%
    58
    185 and up
    36.94%
    164
    1994 Mazda Protege DX - Automatic - 47K miles - AM/FM/Cass - 13" Hubcaps
    169,9XX, 93 DX original chassis and B8
    owned it since june 2003 when it had 123,XXX
      139,960? on mine. Owned since Oct. 18, 2004, original engine, trans, and body panels. Bought with 132,000 miles. I haven't added a lot of miles, but the ones I have added were very hard.
        121,xxx I bought it in 2002 with 107k miles.
        Eat ****.
          135269 on 93 egt 175 177 174 178 on compression nice and strong. want something amazeing tho my first gen escort a 89 (not a mazda) had 435 before the motor finally went on me was strong till its last day when it died because it decided it was a good idea to put a rod through the block.
          mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
          suspension: s/r struts intrack springs and intrax sway bars 15x6.5 rims kumho mx tires 205 50 r 15
            My motor has a bit less than 80k on it, the car has 168k or so.
              Mine is at around 280,xxx khms and no problems since I got it back in May 2005, runs very strong no porblems except the rpm drops low then comes back up almost stalls sometimes when I put my clutch in!
              Fully kitted, Sparco seats, 17 inch AR rims, JDM parts to the MAX, Dropped 2 inchs, 10.1 inch MX3 GS big brake, Custom Copper paint, CF Hood, RESIDENT MAZDA PARTS GUY! I Work For Agincourt Mazda
                ~120k purchased at ~63k back in 98. I killed the engine about a year ago after I bought the gtr. Was on the origonal tranny and clutch.
                2013 Dodge Dart Aero
                  My 323 have around 215 000 kilometers I think 110 000 miles. With a B6 Sohc.
                  Bx motor's are the tuffest one yeah!
                  TANK 1: BG Mazda Protégé LX 90 Frame 20-07-03
                  TANK 2: BG Mazda Protégé SE 93 Crash 23-02-04
                  TANK 3: BG Mazda 323 BG GT 95 Crash 03-12-06
                  TANK 4: UF Mazda B2600 4x4 92
                  TANK 5: BG Mazda Protégé DX 92 - SOON
                  From Montréal, Québec, Canada
                    225 on the chassis, 224 on the original motor, 3rd clutch and tranny, 15 miles on the built motor, and 25k on the current motor
                      Our 323 has 128 thousand Kilometres,runs great, we just had the Ontario emissions testing done on it and the Mechanic said it tested clean as a new car.
                      Actually some of the readings were lower Than my Subaru legacy GT and it is almost new with only 40 thousand Kilos.
                      Pat.
                        i just cracked 122XXX yesterday
                          Lets see, I bought mine back in Feb. 03' with around 124,000 miles, Now I'm about to crack 170,000 miles in the next couple of weeks. Orginal motor and tranny. Had original clutch when I bought it, changed it, had warranty issues with that one, so then I had to do another one about 6 months later.
                          Sure would be nice to find a low mile chassis like yours Spectrum.
                          93' 5spd DX
                          R.I.P
                            141k ish, 5axles, 1 clutch and 1 exhaust system later. still running strong and hard!
                            Maroon 1995 Probe SE
                            Beige 1994 Protege DX
                            Silver 2001 Protege ES
                              bought in feb 05. 154,xxx on the clock. all original motor and trans.
