Obd2 Connector
    Obd2 Connector
    Hi. I'm a newbie to this site.
    I have a 95 protege 1.5 DOHC and from what I'm told, it is OBD2. My question is would a normal OBD2 scanner fit the diagnostic connector in the engine compartment or does it take a special connector? If it is different, where can I get one with out going to the dealer?
    The standard OBD-II connector will not fit the under-hood diagnostic connector. I believe you can just can an adapter for an OBD-II scanner, and besides the dealer, i would try any place you know of that sells the scanner.
    Mods:
    JDM Headlights + Corners
    JDM Tailights
    1st Gen LX Black Wheels
    Shaved Side Mouldings
    Second hand 'High-Flow' Muffler
    Cone Filter
    KYB GR-2's + Perf Lowering Springs
    E-Bay front strut bar
    Gauge cluster swap w/ Tach + Indiglo gauges
    40% Tint on side windows, 20% on rear
    and the best custom 3rd brake light overlay...'ZOOM'
      hey at advance they can read codes for cars 95 and down
        The OBD-II diagnostics port is in the car - under the steering wheel, close to the hood release.
          I didn't realize that the 95 pros were OBDII. I thought that was only 96 and newer vehicles except for certain makes and models.
          I know it's spelled protege! I just can't change it. Deal with it!
            I'm pretty sure they all have the OBD connector, but earlier models aren't fully compliant with OBD-II.
