NEEDED: ARP head stud nut torques!
    I can't find my sheet anywhere and their website apparently doesn't have it (bastards!) Anyone got theirs?
    Ask me about engine management!
    Here ya go.
    --Ferdi
      yeay!
      For old usefull post.
      Beater=/= Sleeper
        True.
        When I called them last time, their computers were down- tech guy gave me the torque specs based on the stud size.
        92 240SX: KA/T25, nerd mobile
          I think this thread need to be stuck. I've used it twice.
            done deal
                pretty sure i TQ'ed them to 68 or 72 i forget which, but a little extra doesn't hurt so long as its not excessive
                  Gotta +1 this thread, thanks for sharing..I just used the info for main studs.
                  1993 Ford Festiva - Fiona/b6 swap
                  1997 Ford Aspire - Peaspire/rescued restored and sold
                  1994 Ford Aspire - Kiazord/BPG5MR Swap
                  1999 Mazda 626 - exDD, sold
                  1997 Ford Aspire - Babyspire, stock low miles&clean
                  1994 Ford Aspire - Crustyspire, scrapped
                  2003 Chrysler T&C - grocery getter
                    They changed their minds about the head stud torque, the paper I got said 80 ft lbs.
                      I would not torque them past 65ft-lbs. There was a guy on miata.net that cracked his head with 85ft-lbs. The resulting discussion ended up with people agreeing to stick to the lower 65ft-lbs or even less. When FM/ARP initially designed the head studs, the ARP engineer came up with 48ft-lbs...
                      --Ferdi
                        hrmm..... that makes me wonderwhat i TQ'd mine buddies to on all 3 engines. i know it was well above 65ftlbs
                          I haven't heat cycled the engine, would I have to get a new HG if I loosened the nuts and only torqued to 65-70? The paper said 80, so that's what I did.
                            From what I've been told, the head studs should be re-torqued / checked after a few months after initially installing them. I've done this on a few engines just as a sanity check.
                              ^x 2
