Hi everyone, I'm new here.
Ok so here is my problem, when my car is at idle and i give it some gas it sounds like something is blocking the airflow and the car almost dies, but if i rev it up a little gradually then let out the clutch it will move. So if it's at idle and I give it to much gas right off the bat it almost dies. It sounds like something is blocking airflow?
So I switched out my intake vaf with my friends vaf from his old protege, it still does it. So i'm confused as to what it is. Unless it is the vaf and both mine and his are going bad. The car idle's perfectly fine it doesn't miss at all. So the spark plugs seem to be fine. Any idea what this problem is? The engine light does not come on except once this morning when I first started my car it was on for about 30 seconds then went off. Hasn't been on since. I reset my ecu by unplugging the battery, that didn't fix it either. Anyone had this problem?
VIDEO LINK
I searched the forum and found some similar posts, but no definite answers.
I read to replace the o2 sensor and the tps sensor.
VIDEO LINK
