Anyone else here lift??
    So what is everyone's max bench's and so on.....
    I attempted 330lbs the other day, but I got it about 1/2 way up, and it wouldnt budge no more. So 305lbs still stands as my max 1 time bench.
    Squats on the other hand, I did a 3 rep max, and put up 435lbs.
    And dead lift was 305lbs as well.
    Eat ****.
    i used to lift off and on. i never took any supliments and was benching 265 when i only weighed 170. im also 5'11" so its not like im one of those short fat kids that benchs a bunch cause i have short arms.
    i did 65 dips when i was in highschool 8 years ago. but i only weighed 145lbs then. <-- that is 5th best all tiem at my highschool at the time. since at my heavier weight of 160 i do 62.
    NEUMAN
      I lift weights at least once a week. I've been doing it on and off for the last two years.
      I'm 5'8" and weigh 165 lbs. Last year when I was lifting more, and I was at my biggest, strongest point, I bench pressed 265 lbs one time.
      I haven't done legs in years, but when I was doing them, I benched about twice what I could squat. That's kinda bass ackwards.
        starting to lift again. never done one time reps. but just did my workout and did 3 sets of 15 at 170. and i am only 135 lbs.
        mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
        suspension: s/r struts intrack springs and intrax sway bars 15x6.5 rims kumho mx tires 205 50 r 15
          Yeah......lifting cock.
            what kind of workout?? If u only did 3 total sets of 15 reps, and call that a workout..thats weak!
            Eat ****.
              if your talking bench your a liar or don't know how to add very well. no one that weighs 135 just goes and starts lifting one days and pounds out stuff like that. a person that lifts on a regular bases is happy to lift there own weight 15 times let alone 3 sets of it and 35 lbs more. i used to work out with body builders. like i was friends with them and they gave me tips all the time. so unless you where one at some point i can't imagine this.
              i hear that also! when i was workign out i felt as tho it was a waste of my time unless i was there for atleast 60 minutes. not counting any cardio i may have done.
              NEUMAN
                Definitely.
                Mark you pussy.
                I need to lift for about a 1 - 1.5 hours to feel satisfied.
                  **** me a pussy. i went with that workout to get started back up. what needs to be noted is i have 3% body fat. and that was just the bench also had 3 sets of curls 5 sets of dips . and 8 2 minute leg lifts and 100 crunchs. and 3 sets of lat pulls.
                    trust me im not bad at adding.
                    just started working out again after a long lay off because of work and the past 3 years had been really hard on my health wise turns out i had strep in my blood as a virus wouldnt go away no under control for the last 6 months so finally able to function properly.
                      jo how you gonna call me a pussy you the one who keeps sending me pictures of you on your knees with your ass in the air asking me to come over.
                        for having bad health and not working out for some time i would not see you as 3% body fat. then just throwing down crazy weight like that? your stories don't jive son! how about posting some pics of you instead of your wife.
                        NEUMAN
                          I lift at least twice a week, but I never **** around with that "1 rep max" stuff. I like to do a conservative workout: 3 sets of 12-15 reps a piece on incline, decline, and flat bench press. I usually do 105-115 on each bench. If you're counting, that's 9 sets, over 130 reps total with little rest time to keep my hear rate up. And that 's just my pectorals. I'm 5'6", 159 lbs. I also like to curl a variation of 5 different ways with 25 per side, and at least 50 reps per side. And I never life for more than one hour. More than that is detrimental to your muscles. I also do cardio, a 3 mile run, after every workout.
                          My goal is to get bigger in my upper body, but keep lean.
                          So I figure, 160 with less that 5% BFC will make me happy.
                            I Bench @ minimum 4 sets every other day.... except for when im on vacation...
                            Damn im missing lifting. being out of town with no access to weights....
                            I don't max lift but i lift to keep fit.
                              I'm not even going to dignify myself with a response to that.
                              how about posting some pics of you instead of your wife. NEUMAN
                              Maybe you can do that in PM, but keep the pics of Jenn coming!
