Hello people
I need help in installing the MAP-ECU on my supercharged 1.6 LX. I cannot make any further upgrades with the restrictive and bothersome MAF system on these cars...
What I precisely need to know is which wire is the air intake temp wire and which is the air flow signal wire coming from the MAF to the ECU? There are 5 wires in the MAF connector: black (ground), white w/ red stripe (power), green with black stripe (?), blue with white stripe (?) and a beige/orange/vomit colored wire (?). Also can anyone tell me what wire is the TPS signal and the negative coming from the coil?
I have the PCM manual for the 1.6 ZM DE, but it has up to 104 pins indicated on it, whereas the PCM connectors are a 26 pin, 16 pin, and 22 pin. That makes 64 pins, so I suppose you need the SSS 104 pin spreadout connector to be able to figure what pin is what. Is this right?
Please help anyone!
Thanks
Motamazda
Please help anyone!
Thanks
Motamazda
