idle trouble
    idle trouble
    if anyone has trouble with the idle dropping suddenly at lights or anytime when stopped try doing these things first might save you lots of cash
    ive had this trouble for a while now and its finaly stopped firstly try
    tapping the throttle position sensor with the handle of a screw driver its a small black sensor conected to the throttle body its on top and on the fire wall side of the throttle body do this when the reves are all over the place if the revs correct thats the problem
    you will need to get it pulled off and cleaned as they are water cooled
    next get you sensors checked MAF, O2
    if non of these work try putting injector cleaner in and buy a can to throttle body cleaned and clean the inside of the throttle body if you notice any difference get you injectors and throttle body pulled of and cleaned
    also dont forget the simple stuff that might have been overlooked like filters plugs and leads
