Compressor Wheel sizes
    So you can put the vj11 housing on the vj20??
    Oh duh why dont i try this my self since I have both turbos. Im curious
    Boosted 1990 4WD
      i thought the vj-11 had a bigger exhaust and a smaller intake compared to the vj-20. which is why it spools a little slower than the vj-20 and doesn't have the same power.
      JACK.
        the vj11 has a p20 housing the VJ20 has a p15 housing. housings are interchangeable. if your looking to flow more then the VJ20 housing you could put a VJ11 housing on. it will spool slower but MAY proove some increase in top end.
          i think you would see 0 gains with the larger a/r exhaust housing on a vj20. you'd need to upgrade to a much larger compressor for it to be worthwhile. in that case, i think it would be.
            so there wouldn't be much power difference after spool up between the 2 turbos really? assides from a differences in spool time (probably around 4-500rpm)
            JACK.
              probably not much of a difference at all.
                hmm i might be inclined to see off my T3 and go with a vj-11 hybrid then...hm...that with a vj-17 cold side would rock!
                JACK.
                  is the VJ17 larger then a VF12?
                    vj-17 is the t-bird/mustang svo/merkur turbo...no clue on the sizing Ryan, i just know its a nice upgrade for a vj-11
                    JACK.
                      JACK.
                      I had a vj14/vj17 hyrbid on my mx3 with the b6t block and b6de head.
                      It was an awesome street turbo, i was maxing out the stock 330's at like 14 ish lbs(bumped fuel pressure and ran 17 psi one night, lots of fun)
                      Before i blew it up (long story) it would spin all of first/second then bark third really hard, this was on a factory replacement clutch (long story again).
                      It may run out of breath up top for a BP, so the larger vj11 exhaust housing may do the trick.
                      If i didn't go with my T3/T04E i would have had this turbo rebuilt.
                      -Turbo Mx-3
                        VF8/10/12 are still larger then the vj17 just so you know
                          JACK.
                          the T-Bird/VJ-11 hybrid,would not outpreforme the smallest .42/.48 t3,
                          the hybrid would spool faster but thats it.
                          but people that are looking for vj-20's all the time, could/SHOULD just go and find a
                          IHI from a t-brid (87-88 t-brids)and a VJ-11 exhaust housing(mx-6 turbo) and make a hybrid and run that,, making the hybrid is simple as just swaping the vj-11 E-housing onto the t-brid turbo, althou the bolts are ussally a pain to get out!!!!!!!....!!!!!!!..
                          plus IIRC the vj-11 e-housing flange can be reamed out a little and the bolt holes fit the stock gtx e-manny.(im not 100% sure about this,but i remember reading about it a long time ago)
                          it would be a lot better than the weak vj-20 and alot cheaper and easyer to find
                          5 boosted bp cars,why...
                            thats what im talking about Ryan1, if i were to go with a 11/17 hybrid...parts would be cheap and parts would be simple to find. If i destroy a turbo, it won't bother me as much lol.
                            And yes you can slot the bolt holes on the vj-11 to fit the bp-26 manifold
                            JACK.
                              IHI VJ-20 Left - Garrett "Ford" T3 Right
                              Drew
                              '95 EGT 1.8
                              T
                              '93 ELX 1.9 SC
                              '91 ELX 1.9
                                & thats a bolt/slide in?
