Compressor Wheel sizes
    so what yr is that wheel off? i grabbed an inducer and exducer off a volvo at the yard today... didnt check it out much yet, but it was off the boxy style volvos figure it was worth grabbing for the hell of it... the flap was deffinatly a bit bigger then the stock vj20 little mini flapper....lol....
    heres a few pics, one is the vj20 25.9mm flap next to the volvo 35mm flap and a few of the vf11 next to the volvo turbine ,inducer 41.5mm, and exducer 55.9mm
    92 protege lx-
    94 protege lx-
      Originally posted by yunvmyegt View Post
      so what yr is that wheel off? i grabbed an inducer and exducer off a volvo at the yard today... didnt check it out much yet, but it was off the boxy style volvos figure it was worth grabbing for the hell of it... the flap was deffinatly a bit bigger then the stock vj20 lil mine flapper....lol....
      Not sure of the year of car/turbo it came off of all we know it might be one of the 1.9T's im pretty sure.
      My baby 93' Protege Lx--R.I.P
      New Baby 94' Protege Lx Black
      91' Miata - SOLD
      93' Protege LX new Project (no rust)!
      Mods: Protege:
      Engine: Fully built with wiseco 9:1 +1mm ceramic coated tops and molly skirts, M-tuned H beams, ACL Race rod and thrust bearings with King Mains, Arp Mains ,rod and head studs,3 lbs lightend crank, Everything is ballanced, spec stage 3 clutch,lightend flywheel, RX7 Afm, Fidanza Adj. cam gears, timing,Cut intake manifold from BPT323, exintake cam swap,full port and polished head 1mm stainless oversize valves, vf12/vj20Turbo, 3" custom full exhaust w/external wastegate,3" E-Cut, Eclipse crushed BOV , Fmic, Aem Urgo wideband, Autometer boost gauge, Magnaflo Muffler,batt relocated to trunk, slight wire tuck with engine bay fuse box under dash Bp26 ecu
      Suspension: Energy Suspension rear trailing arms,Es Front Sway bar endlinks,Zx2 Front Sway Bar,El Sport w/bilstein mono tube struts and don't know what springs, Suspension Tequniques Rear Sway bar with Es endlinks,mx3 rear lower tie bar. corksport SS brakelines and clutch line.
      Exterior: Adler Racing 16"s ,Mx6 Front lip,EGT Glass Sunroof,Edm Headlight & corners EGT side skirts,Gt Led wing, Led interior 3rd brake light
      Audio: few things polk momo 6.5 components, VW Monsoon Front Componants with monsoon amp,alpine head unit
        Where'd you send the compressor cover to get machined? Turbo city? GPopshop?
          vf8 turbine wheel is 52.5/46.5(2.06"/1.83"), and the compressor wheel is 56/43.5(2.20"/1.71")
          heres some pics , and the exhaust wheel compared to the vf10....
          92 protege lx-
          94 protege lx-
            did you ever get a answer on what volvo the wheel is from?
            5 boosted bp cars,why...
              I just found another hybrid.... :D
              Mexican: "You wanna race for titles?"
              Mormon: "lol, no, I don't want your car."
                which would be?
                92 protege lx-
                94 protege lx-
                  I don't know for sure, it is strapped to a vf10 I just got from australia!! It says it is a ihi my34, which come on boats... And when I look at the part numbers it is bigger than a vf8 but smaller than a vf22... and it looks to be the same size or bigger than a vf12...
                    Here is a funny thing, this might be a turbo that came on a crate engine from japan to Australia.... Who bets this thing will make me a couple more ponies on the dyno??
                      pics & measurements please clayton
                        Vj17 t-bird IHI-inducer:39.0mm exducer:52.5mm
                          thank you chris, i updated/added that to the 1st post
                            the upgraded wheel we had machined to put into a VF10 compressor housing (same housing as VF8/12) is indeed a Mitsubishi TD04-19T Turbo Compressor Wheel 46 / 58 mm accordingly
                              Volvo t70R used a 19T wheel.... http://www.stealth316.com/2-turboguide.htm (19T compressor wheel flow cfm) click on the check mark for the maps.
                                why are we not posting the turbine sizes too?
