Complete Suspension List
    Originally posted by goodorange
    no
    I second that.
    lol, I believe I answered that in a private message he sent me a while ago.
      AWR makes more than sway bars for our cars.
      They have adjustable front and non-adjustable rear strut mounts, and strut bars too.
      AWR is dedicated to building high quality performance parts for race winning cars, specializing in fabrication, chassis design and building. composite design and forming, aluminum and steel coach work, high performance radiators, racing, race track support, race car retrofitting. Builder of Formula Atlantic rotary engine conversion, Mazda performance parts, Speed World Challenge proteges.
      Rear strut mounts are kinda pricey at $199.50/pair for the rears.
      High performance motor, engine, and transmission mounts for Mazda and Ford.
      Front strut mounts can add up to 2 degrees of camber and cost $125/pair.
      Strut bars are $139 for polished aluminum, and $295 for caborn fiber.
        I have KYB whit gold line springs that springs are great y put 100mph and not yup is great in front is like 2.0 back 1.7the springs cost me $165 I am from Puerto Rico and mi cars is 96 ES
          Gmax progressive lowering springs part# 30MA02 lower 1.5" front/rear
          PI lowering springs part# 40-123 (40mm (1.575") drop front/rear)
          Avo lowering springs part# AV-50-008 (40mm drop)
          There are a bunch of others that can be found at the last website. I think all of them are made for the Lantis but they're supposed to be interchangeable with the BHA Protege.
          Sadly, none of those are available in the US.
            I know this might be a newbie question but does any of the 3rd gen suspension interchange with the 2nd gen?
            97 protege dx few mods
            94 escort lx heavily modded
              I know lowering springs and part numbers are listed here but does anyone actually have the year interchange for the protege. I know spring rates differ between year but do they actually match up between all gens?
                they don't interchange from gen to gen, speaking in u.s. specs.
                now what i'm trying to determine is, is that:
                can a 1st/3rd-gen strut bolt on to a 2nd gen? i would be using coilovers anway.
                because i know the spring perch is going to be different.
                Almost there
                jdm tails... check
                jdm bumper... check
                ms lip... check
                ms grill... check
                ms sideskirts... check
                ms rear skirts... check
                ms spoiler... check
                ms struts... check
                Still trying for a bp swap..:
                  No one knows. Only way to find out is if you take a strut from a 1st/3rd gen at the junkyard and try installing it on your car.
                    check out my threads in the 1st and 3rd gen sections:
                    not much happening in the 3rd gen section.
                    Almost there
                    jdm tails... check
                    jdm bumper... check
                    ms lip... check
                    ms grill... check
                    ms spoiler... check
                    ms struts... check
                      According to their site BC Racing makes coilovers: www.bcec.com.tw
                      BC Racing reportedly makes the coilovers for Megan Racing and the low end Apexi ExV series. So Megan Racing should be able to get them.
                      And here's another link to some kyb performance struts, stainless brake lines and MS springs...
                        i found some goldlines for the pro
                          anyone think that these will work? it shouldn't drop it too low where my wheels rub my wheel well if i'm on 14s right?
                            rubbing matters, but if you have the correct offset of your wheels, there s/b no problem.
                            dood have you even seen how much of a gap there is on your car? if you lower 3" or more they wheels/tires might rub, but that depends on your offset, like i said.
                            the 1.8 and 1.7 drop is not going to hurt anything, assuming you have the correct offset and tire size.
                            btw, use some common sense. you could go outside and easily measure the gap on your car. and figure if the 1.7/1.8 drop is going to hurt or not in your situation. and of course they're going to work-the goldlines.
                            Almost there
                            jdm tails... check
                            jdm bumper... check
                            ms lip... check
                            ms grill... check
                            ms spoiler... check
                            ms struts... check
                              nice, i'll get those AFTER i do the engine swap tho sucks.
                                1.8/1.7 is nothing, go lower strutman!!!!!!!!!!!!!!!!!11
