Complete Suspension List
    ksport makes coilovers for the 2nd gen
      right on what would you go for B&G or H&R lowering springs?
      -Tires...205/40/17z
      -Spectre RAI
      -3a racing muffler
        i've got B&G with kyb struts.
        and it rides really well.
        but then again. my struts and springs are highly modified.
          yea i just dont wanna spend all that money on coilovers when all i want to do is just lower it i could care less on how it rides, even though i keep hearing coilovers are a ride from hell haha thanks man
          -Tires...205/40/17z
          -Spectre RAI
          -3a racing muffler
            can 3rd gen springs fit on 2nd gen?
            -Tires...205/40/17z
            -Spectre RAI
            -3a racing muffler
              No.
              Broke Status FTW!
                NAPA Part numbers for Drilled & Slotted rotors
                PR86130L Left Front Drilled & Slotted Rotor.
                PR86130R Right Front
                PR86129L Left Rear
                PR86129R Right Rear
                  Thought this was for struts not brakes
                    Sorry if it was the wrong place to post them, I just categorize brakes in with "suspension"
                      Its easy to say as long as its lowered and dont care abt the ride. I was in the same boat too, I even was just planning on cutting my springs just to have the lowered look. But then again, you dont have to put too much to have the look and the nice ride. Thats why since Im going for the jdm looks, I went with the JDM RS-R springs and the gr2 springs.
                      JDM inspired protege with super rare mazdaspeed parts.
                        So what about Bushings, move Bars, and other revocation areas that I can't think of at the moment??. . . . . . . . . . .
                        surfers paradise car rentals
                          i have some red lowering springs cs 205 dz. what brand are they???Click image for larger version
                            i've purchased B+G springs and regular gas shocks....
                            and this is how it stands... im on 17 x 7.5 +45 offset...no rubbing issues whatsoever
                              [ATTACH=CONFIG]63913[/ATTACH]
                              [ATTACH=CONFIG]63914[/ATTACH]
                              are you using the b+g Extremes? whats the drop on those springs?
                              also white size tires are you using? and your rims are +45 offset?
                              how are the regular struts holding up? bouncy ride on bumps?
                              Almost there
                              jdm tails... check
                              jdm bumper... check
                              ms lip... check
                              ms grill... check
                              ms sideskirts... check
                              ms rear skirts... check
                              ms spoiler... check
                              ms struts... check
                              Still trying for a bp swap..:
                                use new bump stopsClick image for larger version
