GTX BP26 ecu diagram? TPS conversion (3 to 4 wire)
    I don't really think it matters. It's the same wire IIRC
      oh ya answer his question but not mine, thanks bro!
      Anyone knows what 9K rpm feels like? I do
      93 Mercury Tracer SW
      01 Honda S2000 Future Boost
        the only thing megasquirt would use the tps for is accel enrichments, and you can just have that be map based. So you really dont need the tps
        NW MAZDAS
          is that right? i have purchased a 4 wire tps for nothing then
            yeah my car has been running just fine, and i dont even have a tps plugged in hah
            NW MAZDAS
              ya thats strange cuz i have MS and everything hooked up and yet my MS cant read the TPS correctly! ugh what a waste of time.
                AFAIK you need the 4 wire TPS for megasquirt. its a full range voltage scale instead of a 3 point system 0 50 100 or whatever it is again.
                if its not working try re-calibrating it
                  hmmm i will have to look into to again once i get my manifold and WG.then ill retune and look into it. thats crazy cus we tried it so many times
                    just did this today thought id add some pics make it a little more clear for some people going to do this.....im going to do a write up on how to do this on my build threadClick image for larger version
ID:	1229454Click image for larger version
ID:	1229455Click image for larger version
ID:	1229456Click image for larger version
ID:	1229457Click image for larger version
ID:	1229458Click image for larger version
ID:	1229459Click image for larger version
                    handed down to my old man : 1994 Escort gt
                    Race car: 1991 EGT BP/bpt
                    http://www.wihandyman.com/forum/show...racecar-s-life
                    daily: 2004 mazda 6
                    http://www.wihandyman.com/forum/show...678-TheSexySix
                    Welcome to Canada
                    ''It's a shame that today's car forums have "fashionistas" instead of gear heads''
                      The 4th pin that needs to be connected when swapping the TPS is just a 5v source right? If so it does not matter if it is coming from the VAF or the ECU. Nobody actually has stated the purpose of the wire here so i thought i would bring it up.
                      Which means, splice the 4th TPS wire into pin 2k on the ECU plug, and move the wire currently on 2L and move it to 2M. 2M does not need to be reconnected as it is not used in the NA harness and the NA cluster does not have a speed sensor in it, I would however cap of the wire coming out of the plug/harness to prevent shorting the ECU/Harness by mistake.
                      Someone should clean up this thread, everyone voicing their opinion on the matter makes it confusing.
                        I caught my mistake, post edited to reflect the way I have it run now.
                        I soldered the 3 wires color-to-color, and ran the 4th wire to the LG/R wire at the ecu connector. Then I took the LG/W wire and ran it to the B/LG wire inbetween the LG/R and R wires.
                        Btw, this is in a 92 mx3 with a manual harness for a 1.6 SOHC, and a BP26 ecu.
                          ECU plug should look like this
                            Ok, so I'm having issues with this again. It is wired exactly like everyone's writeups say: color to color at the TPS plug, fourth wire run to LG/R at the ecu, and the LG/W relocated to the B/W wire between the Red and LG/R wires in the ecu plug.
                            When I turn the key on, the TPS reading in the megasquirt slowly creeps up from 0% until it hits about 70%, then holds there until you turn the key off. Moving the throttle has no effect, it doesn't read it at all. Any thoughts on what could be wrong here?
                              Anyone?
                                2m to 2L. Iirc. I'll check when I get home
                                Sent from my iPhone5
                                using Tapatalk
