Page 13 of 13 FirstFirst ... 3111213
Results 181 to 186 of 186
Thread: Questions about motor swaps....
  1. #181
    my name is a verb now Turpro's Avatar
    Join Date
    Jan 2004
    Location
    Cincinnati suburb Ohio
    Posts
    17,189
    Feedback Score
    73 (100%)
    Maybe a bell housing swap?
    Quote Originally Posted by jay View Post
  2. #182
    zoom zoom irishkev90's Avatar
    Join Date
    Aug 2009
    Location
    Queensbury, New York
    Posts
    3,171
    Feedback Score
    0
    I'll have to if what Shawn says is true. I just posted the question over at mazda626.net since I don't have an engine here yet.
  3. #183
    SHAWN! MD323's Avatar
    Join Date
    Apr 2005
    Location
    South FL
    Posts
    6,436
    Feedback Score
    17 (100%)
    when I get home from work ill throw up a picture of my KL bellhousing against the BP's
    internally they are the same (when comparing similar years)
    thats probably where the idea of them bolting up comes from.
  4. #184
    Registered User
    Join Date
    Mar 2014
    Location
    mt sterling
    Posts
    2
    Feedback Score
    0
    do they make turbp manifolds for the 1.5 and headers
  5. #185
    Registered User
    Join Date
    May 2014
    Location
    Philippines
    Posts
    2
    Feedback Score
    0
    Hi guys! Newbie to mazda protege. Bear with me for this is kinda long.
    I got a 96 model 323, recently changed the engine (1600 DOHC) as it was going out and replace with an BP1800 DOHC. The swap was fine however, the idling is hunting so we figured that the throttle & idle air was dirty so cleaned it. Idling still the same. goes up and down between 1.2k to 500 rpm. I then removed the idle air that came with BP engine and put in the old one from the old engine and also the MAF.
    Idle became stable, though if I switched on the A/C, it goes down from normal idle of 800 to 400, so I adjusted the idle between 1k - 900. Used it for a month without any problems.
    Yesterday, I did an oil changed and advance the ignition timing to 14 degrees. Drove it around after and everything was fine. Before shutting the engine, I rev it twice to see if smoke would come out of the tail pipe and the idling became erratic again and stayed on 1,500k rpm. I adjusted the idle to 1k, shut off the engine. waited a few minutes the started it. Idling was between 500 and 300, so adjusted it again to 950k. This morning, When I started the car, the idling stayed at 1,500k rpm again. I also noticed that the o2 sensor located at the exhausted manifold was not connected, looked for the wire but there was none. Probably the tech that did the wiring somehow forgot or deleted the wire for the o2 sensor.
    What could be the cause of the erratic idling? could it be the o2 sensor or is the idle air sensor bad? Thanks
  6. #186
    Registered User MSP96's Avatar
    Join Date
    Apr 2010
    Location
    Mexicali BC
    Posts
    21
    Feedback Score
    0
    Has anyone tried to put the ZL engine in a 2nd gen?
    My Z5: The slowest car in the world (13 seconds on 1/8 mile)
    Midnight Imports Team from Mexicali BC, México.
    In search of Mazdaspeed parts...
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
Similar Threads
  1. Motor is in, a couple questions
    By FazdaBoy4ever in forum Engine/Drivetrain - BG Chassis
    Last Post: 06-16-2009, 06:51 PM
  2. Noobie to motor swaps
    By deathtrigga in forum Engine and Drivetrain Swaps
    Last Post: 09-24-2008, 12:04 PM
  3. some questions about seats, swaps, and sound
    By mad in forum Exterior/Interior - BHA Chassis
    Last Post: 08-26-2008, 12:38 AM
  4. People doing Motor Swaps.....
    By Clappy in forum Engine/Drivetrain - BHA Chassis
    Last Post: 07-26-2005, 02:42 AM
  5. 1.8 Liter motor questions
    By RockShox in forum Engine/Drivetrain - BHA Chassis
    Last Post: 04-01-2004, 09:27 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
