91-96 Escort GT vs. 90-94 Protege LX - important similarities and differences
    You can make the alternator work don't get me wrong ... it's simple and so is the PS pump, just change the high pressure pump that attaches to the pump.
      My Protege GTs BP seems to have a sensor/plug at the front of the block...the wire that hooks up to it looks like a typical household chord. It's for coolant since i tried to remove it...coolant leaked out. The plug is 3 prong.
      Do i have to swap this **** over to my EGT BP that im dropping in today???
      PS. i couldnt find out where the wire/chord went to.
      JACK.
        sounds like a block heater to me........ if you dont want it or need it i'll take it!!!
          The canadian cars came with block heaters, my original motor had one.
            Turns out the EGT motor has a block heater too, but its at the back of the block near the oil filter looks like im pluggin this bitch in come winter hah
            JACK.
              Originally posted by therieldeal View Post
              If you have a 91-93 escort, only one of your rear lateral links is adjustable.
              My 91 and 93 GTs have adjustable links on both sides, as did Pat's (iirc, it's been a while since it was stolen).
              92 240SX: KA/T25, nerd mobile
                it may have been replaced at some point, as all replacement links are the adjustable type. ive seen many many escorts in the junkyard and ive owned and/or worked on a few (91x2, 92, 93, 94x2, 95) and only 94+ ever had an adjustable drivers side rear link. perhaps it changed mid-year in 93?
                btw where is head wound city, CT?
                  Mine does not and it's a 91
                    Not sure- for some reason I've only seen LXs with the one adjustable, the GTs i've owned and worked on had duals. Pretty sure the ones on my cars are originals, but at this point, who knows.
                    HWC is a band. Just felt like it would make a great location for forums.
                      hmm, weird.
                      91x2, 93, and 95 out of that list ive owned/worked on were GT's. the others were LX's.
                        oh, just wanted to point out that a mazda fuel rail works just fine, you just need to use standard fuel hose from the filter to the rail, and the ford FPR.
                          cheap ford junk
                          Whoops did i type that?
                            arent the axles and wheel studs the same as well?
                            "Beer is proof that God loves us and wants us to be happy"
                            -Benjamin Franklin
                            i wish my grass was emo, then it would cut itself
                            -dedicated to sling blade, aka, meltdownsky
                            this is a horrible trick and should be deleted immedately - wheresthericego
                            http://www.wihandyman.com/forum/showthread.php?t=35130 - BWAHAHAHAHAHAHA
                              yes
                                yes, i think i mentioned that somewhere in there.
