91-96 Escort GT vs. 90-94 Protege LX - important similarities and differences
    My 93 also only has one adjustable in the rear and my 95 has both...
      Originally posted by bpt323 View Post
      cheap ford junk
      Whoops did i type that?
      yeah, well... your mom.
      92 240SX: KA/T25, nerd mobile
        welcome back
          hey, can you simply swap the whole steering column/rack assembly from a pro lx to an egt?
            That's not very f___in nice....
            cheap ford junk
            kozzman555 wrote: arent the axles and wheel studs the same as well?
            Shhhaaaddd aaappp! You flippin nutso!!
            I got One, The EGT A/C compressor is not compatible for a Mazda and so on. I am a proud owner of a Cayman EGT and maybe another soon. So be flippin nice ya'll. lmao
            David
            David
            sigpic Ky
              Hello do you need these parts for an egt?
              Pm me If so!
              David
              sigpic Ky
                added a note about the firewall wiring harness grommets being different sizes.
                  I'm doing a 90 Protege LX swap into a 93 escort lx wagon do you think that from the firewall forward every should line up perfectly or is there anything i should watch for? Also i noticed a difference in the wire harnesses near the Mass Airflow sensor! is there anything really different or does it jsut look like it? Also.. (sorry) i'm redoing all brake\fuel lines but am installing a brake controller what is the best Master cylinder to use and out of what car? plus any other info you have on the differences with these two cars please let me know!!!!!!!!!!!!!!
                    the hole @ the firewall for the harness grommet is larger with a EGT
                      what is this about the Alternator not fitting and the side mount??
                      http://www.wihandyman.com/forum/showthread.php?t=47653
                      my fs thread
                        they fit fine. the bracket that actually bolts them to the block looks different, but the mount and alt are the same.
                          this thread was a good idea.
                          so is the first post constantly edited with all of the confirmed swaps?
                          Next!
                            update to the original post. my 94 egt doesn't have the drivers side rear toe adjustment.
                              it seems to be a mid 94 change then, my wagon was adjustable on both sides
                              i'll poke through and try to update it abit... a havent looked at it in a while
                              glad you found it helpful
                                yea, i think a lot of little changes were made mid 94 to escorts, like that and mine still has a 5 digit odometer.
