91-96 Escort GT vs. 90-94 Protege LX - important similarities and differences
    Originally posted by chrmar View Post
    The sending units in the tanks are different between Mazda and Ford due to Ford using their own fuel system. Everything else will work with a possible exception being the radiator; I know they're different between EGT and Pro but not sure if they're interchangeable...?
    Should be. Just would have to use the escort rad hoses if you run the scort rad in a pro and vice versa.
      the brackets for the radiator are in different locations
        yep, can't swap rads w/o a bit of custom work
          Well, that makes that decision a little easier...!
          97 Expedition XLT - 90 MX-6 LX - 95 Escort GT
            I am glad to have found this thread as well, subscribed as reference.
            Thanks for the info!
              these statements are correct, if you have access to a welder it should be about a half hour affair. all you really need to do is unbolt the stock brackets for the rad, after you get someone to hold the rad in place when another person welds the brackets into place,and you are done. it isn't that difficult just requires access to a welder. i run an egt rad on my pro. works fine
              http://www.wihandyman.com/forum/showthread.php?t=47653
              my fs thread
                I would like to know more on the Escort LX differences compared to the protege are they 90% protege too or is the percentage less with them?
                  No. The lx is a totally different car. Chassis is about the only thing that doesn't change
                    suspension will interchange, brakes are the same as the protege DX/323
                    obviously the engine bay is 100% different
                      I know my LX was made in Mexico it's VIN # starts with a 3 that is Mexico code.
                        neat?
                          lol he said "neat?"
                          my fs thread
                            ya about the rad bein interchangable. i just went wit an upgraded thicker civic rad lol it works hella good hahaha. its about 3in thick i wanna say.
                            Anyone knows what 9K rpm feels like? I do
                            93 Mercury Tracer SW
                            01 Honda S2000 Future Boost
                              question?-i wanted to know if i get an 92-95 ford escort gt sunroof will it fit right into my 94lx.or is there any other sunroof that will work.
                                94 lx what? protege? if so yes it will fit.
