91-96 Escort GT vs. 90-94 Protege LX - important similarities and differences
    Originally posted by EGTDMB41 View Post
    Lulz, I was. I only yanked the 175k BP05 because it needed a rear main seal. Compression was perfect, just was a leaky bastard. I figured if I needed a rear main, clutch, and oil pan gasket, i should just yank it and be done. Picked up this 120k LTS motor for $125 at a pick-and-pull in Mass, dropped it in, and once adjusting the timing to 16* and putting on my existing header, I ripped off 12 more whp. The 175k motor had timing, header, cut intake, exhaust intake cam, 2.5" CorkSport catback, and a couple other things I cant entirely remember. The 120k LTS motor never got the cut intake or camshaft.
    That BP05 I yanked got resealed, dropped into a 1991 ProAWD with a GT3071 and pulled damn near 400 on the dyno. I think it may even be still running, this was like 8 years ago,
    Was the awd pro on stock rods at 400 whp and were you running the stock usdm tranny.
      I will want to be watching for this project by Blazin674.....
      David
      sigpic Ky
        I am wanting to order rear disc spindles for a 90-94 protégé for my 96 Escort rear disc swap. The diagrams on the dealership websites look slightly different. Will they swap in?
        1988 Mustang LX hatchback *in pieces*
        1991 Ford Escort hatchback mtx *scrapped*
        1991 Ford Escort LX Wagon atx *SOLD!*
        1993 Ford Escort GT mtx *in pieces*
        1996 Ford Escort LX Wagon mtx *rebuilding*
        1997 Taurus SHO *in pieces*
        2000 Contour SVT *mothballed*
        2000 Buick Century Custom *wrecked in Junked*
        2002 Ford Escort ZX2 mtx *SOLD!!!(THANK GAWD I HATED THAT DAMN THING WIH EVERY FIBER OF MY BEING)*
          yes
            Are you not interested in the Escort parts I have anymore? If not, let me know, because I am still planning on grabbing that quote for you tomorrow. But yes, the protege parts are the same.
            Current:
            68 Torino GT Fastback
            86 MR2
            91 F150
            94 Escort Wagon BP swap
            99 Escort Wagon BP swap
            00 Miata LS
            08 Arrow AX8
            14 Mazda5
              Are the thermostat housings the same between GT and LX protege? Just curious since the radiator is different.
                same same
                  hey i have a protege 94 sohc 1.8, i want convert on dohc, and i got escort gt 95 with everything engine,tranny,ecu, but the only thing stop me to do the swap is the harness and ecu, question: do i need to change the ecu and harness and something else? thanks, pro94
                    the DOHC engine will run on the SOHC ecu.... using a mazda harness for a DOHC (or adding wires to your harness for the VICS & 4th disty wire[if its not there]) and the DOHC ecu is your best combo bet.
                    good luck
