i've done a search and i still can't find what i would hook up my remote wire for my amp to any help would be nice!? the amp says i could hook the remotye to an accessory power but whats considered asseccory power?!
What can i use as an asseccory power
I am pretty sure that the cigarette lighter circuit in our cars is switched on and off with the ignition. You could use that.
I think that the term "accessory power" refers to a source that is turned on when the key in in the accessory or run positions.--JJB--
'02 Silver Protegé5 - 5sp - no performance mods, no plans for them
Kenwood Z919 -- Polk Audio speakers
16" alloys w/ 205/50 Bridgestone RE750 (summer)
15" steels w/ 195/55 Bridgestone Blizzak LM22 (winter)
Moon roof - wind deflector - variable intermittent wipers - electrochromic mirror w/ temp & compass
Winter/beater car: 1997 Mercury Mountaineer with 182k on it
OR- use a relay attached to the signal out of the headunit to turn on the sytem. David Navone sells a nice one, or build one yourself via Radio Shack. I keep a few of David's around all the time now, they are very well designed and built.David A. Cameron
"People sleep peaceably in their beds at night only because rough men
stand ready to do violence on their behalf."
Ex Protege Owner- and I still love em!
2004 Cooperworks Mini
2003 Acura TSX
And I swear not another car until my daughter gets a drivers license!!
De Oppresso Liber
Sine Pari
ah yes, i always forget about david's turn on systems
Originally posted by skr33t_rac3r
or you can wire the amp power cable into the remote with a switch and turn it on and off as u like
This is a dumb idea. For many reasons. Not the least of which is: The first time you forget to flip the switch, kiss your battery goodbye.
You can easily install a switch on the remote wire - I generally do this for sub amps, so that I can turn the sub on or off without affecting the rest of the system.
But I don't RELY on that to shut my amps off.
~HH
Originally posted by hihoslva
I think we've all learned to ignore everything you say - especially when you give advice.
~HH--JJB--
Kevin
ah
i had mine hooked up to a switch for like 2 years and never did it do any thing to my amp or my speakers and i even forgot to turn it off once or twice it didnt drain my battery that much. an when it did all i had to do was suck my stepfather's dick and he bought me a new one. he helped me put in the swich so it's his fault but he does'nt care when it dies i just get another becuase i can switch to one of the other 7 batterires i have in the car, i have extra cuz i do that for my stepfather alot and he gets what i need.i is dumb
I've only been here less then a week and already I know that about the only thing this guy tells teh truth about is having "smoked himself retarted"
either that or he's lieing pretending he did because he thinks drugs are cool. (more likely)
what a jackass, you mean to tell me an amp which draws more juice then a dome light isn't going to do ****? what kind of amp did you have a 1.5 volt duracell battery? pah-leeeeseeeee stop talking out your ass.
Haha...it went along with his 450hp and runnin through traffic at 120+....i think he was just tellin us about all the dreams he's had recently but who knows.
What's wrong with the blue remote turn on that's already at the head unit? I'm assuming there is one because there was on in my miata and there's on in my pro. Sounds like the easiest solution since it doesn't require tapping into the fuse box or an aux. fuse or anything.
<marquee>'97 Tan LX 5-speed-Clear corners, "poor mans" grill, 15in. Gunmetal/Polished Konig Holes covered with Dunlop GT Qualifiers, B&M short shifter installed and lovin it, custom leather black leather boot, MazdaSpeed Shift knob, Eibach Pro-Kit, Custom cold air intake Head Unit-Pioneer DEH-3500MP Speakers-Sony Xplod XS-V1621(3-way)6.5s(Front Doors) Infinity 652i(2-way)6.5s(Rear Doors) Pioneer TS-A6990R(5-way)6x9s(Rear Deck) Amps-Kenwood KAC-7201/Pioneer GM-X352 Subs-2-JL 12 W3s in Dual box, redone LED 3rd brake light(doesn't look like crap anymore). More I.C.E. on the way.</marquee>
Formerly '90 White Miata w/ 2 8" Laser Blue stripes
I hate the short nose crankshaft. It took my car away from me.
Originally posted by Iceman112k3
pah-leeeeseeeee stop talking out your ass.Originally posted by sk33t_rac3r
the amp i ahd was a koiler 600 and it powered 2 pioneer 10'sWhen you turn your car on... does it return the favor?
Originally posted by goldstarYes, still have it. It was my attempt to immortalize you in verse.
A Protege driver named Brock
So his engine he goosed
With much too much boost,
