Temp. gauge problem
    Temp. gauge problem
    My temerature gauge is all wierd. During normal city driving the gauge goes where it always does, in the middle. But, at highway speeds the gauge goes all the way down and stays there until I get back onto city roads. As far as I can tell the heater works fine both on the highway and in the city. Is this a sign of a bad thermostat or something else?
    2013 Dodge Dart Aero
    just get a new sensor. $30 from mazda. it is a single pin grey sensor.
    Originally posted by goldstar
    A Protege driver named Brock
    So his engine he goosed
    With much too much boost,
      Check your coolant level also. When there is little antifreeze the temp. gauge will often fluctuate.
      '91 LX
      '03 Mazdaspeed Protege #235
      Originally posted by pigeon
        I had the same problem and it turned out that my thermostat was stuck open.
        Adam
        1991 Protege GTR
        #1739 of 2500
        1991 Mazda 323 GTR Sedan
        MODS:
        GTR motor swap, F&R Familia strut bars, MX-3 Rear Lower strut tie bar, GTX front bumper, GTX grill, EDM headlights & corners, EDM 323 rear garnish, EDM spoiler, EGT sideskirts, MX-3 seats, GTX steering wheel, EGT glass sunroof, WRX hood scoop (functional!!), and other things that take too much space to list.....
        TO DO LIST:
        EDM/JDM rear bumper
        EDM/JDM power folding mirrors
        Repaint car
          Thermostat.
          Coolant Temperature Sensor will create different symptoms.
          My ClubProtege.com Feedback Thread
          MOSI Race Dynamics
          - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
            Sweet, I guess I'll go get a thermostat tomorrow.
