Can someone tell me whether the GTR struts will fit to the GTX spindles. Do the spindles have the same upper thickness to where the strut mounts?
GTR spindles+struts vs GTX
no they do not, GTR ones are thicker as far as i know.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
+1, tabs are farther apart, bolt holes different spacing, ya can't get there form here. 'Course you could always grind em off and weld new tabs on, but you better get the bolt holes in the right place or you'll have alignment issues.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Ok that's what i though. The thing is I have an MX6 spindle with me and it looks amazingly similar to the GTR one Jay posted pics awhile back. It is wider and requires wider tabs. So i'm thinking if the MX6 stuff is similar to the GTR stuff (it really looks like, i have to measure though) i could fit the MX6 front struts and spindles on my 4WD and have a front GTR 5 lug conversion.
Will need to make hybrid axles I believe but i'll measure, I have both at home.
The rear is a bit more complicated though, still have to ressearch that.
Derrick at corkpsort is the mazda parts mixnmatch king. I bet he knows if they interchange.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
look up a 1990 4wd protege, the axles are the same. i have a feeling the length may be way off to use fwd mx6 axle parts.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Because the GTR uses different hubs, the axle outer spline count (the one going into the hub) is different between the GTR and the GTX (If i'm not mistaken) but because the trannies are the same, i'm assuming the inner spline count is the same. Anyways, looks like noone really tried that so i'll take measurements sometimes this week and post up the results.
no, the hub spline counts are the sameEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
