GTR swap (ftjandra)
    Well done ferdi!!! id still say take a bit off of the AFR to put it into the 12's you probably could see even more....
      i guess i need to lean out a bit too, i'm running ~11.2:1 AFR at only 18psi...
      care to share your ignition map Ferdi? :D i know sharing ignition maps isnt the safest thing, but yours is dyno tuned on pump gas with a higher CR than me... so theoretically it should be totally safe on my motor...
        I want to see the how-to on those custom brackets for the a/c and p/s! Very thought out build btw!
          Did you ever share that ignition map?
