GTR swap (ftjandra)
    ~1.5kg/cm2, right around 22-24 psi. Pump gas. I think the sodium ex. valves help keep it alive...there's more info on my silly cardomain page, and the vgarage page...
      Well, the dyno is booked for the entire next week. So, it'll be a while until I get more tuning done. On the bright side, I passed emissions today by just running closed-loop at 14.7. Passed with flying colors at the 25mph test and right at the CO% limit at the 15mph test.
      --Ferdi
        score for passing emmisions!
          Just wanted to give you some well deserved congrats, since it looks like you picked up ROTM. That engine bay and setup is just disgustingly sick
          Well deserved win IMO. And good luck getting the car going the way you want it sounds like it should be a tire frying beast
          Jason
          Yes Its 4wd woot woot
          My Vb Gallery
            does the Gtx use coils ....
              no, it doesn't, at least not as far as I know.
              Posted By: Wheresthericego
              The BP crank is made out of invincible.
                congrats on emissions....lol!! tahts always a hassle!
                  More Dyno Tuning 02/28/2008
                  So, today I pretty much finalized the tuning of my car. Result: 343whp/318wtq at 22-23psi. I purposely made it build up the boost a little slower because the sudden rush of power was causing the clutch to slip just a little bit every now and then.
                  Here is the dyno sheet of a 4th gear pull:
                  And, here is a short video of two dyno pulls ~7mb (right-click, save as...):
                  --Ferdi
                    yee haw man...
                      Awesome results Ferdi. What did you change from your last run aside from the onset of boost?
                        Some timing, but mainly leaned out the AFR from low 11's to high 11's. And, my last dyno pull was done in 3rd gear, but I am not sure how much that really affects the dyno numbers, other than the turbo spooling later in 3rd versus 4th.
                        --Ferdi
                          The engine is always loaded more in a higher gear ... which results in more power produced if everything can keep up.
                            great!!
                            when can i get a ride!
                              oo very nice, so once i get some of this stuff done i should see similar numbers. yay
                              1994 Escort LX Wagon
                              2013 Hyundai Veloster Turbo
                              91 EGT - Junked May 2012
                                Amazing how clean your ride is all around. Perfect details to every aspect. Congrats on the numbers. That's just a beast.
