Well done ferdi!!! id still say take a bit off of the AFR to put it into the 12's you probably could see even more....
GTR swap (ftjandra)
i guess i need to lean out a bit too, i'm running ~11.2:1 AFR at only 18psi...
care to share your ignition map Ferdi? :D i know sharing ignition maps isnt the safest thing, but yours is dyno tuned on pump gas with a higher CR than me... so theoretically it should be totally safe on my motor...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
