Gen 3 Wheel Fitment Guide
    Rishie's guide. Sticky me?
    Mazda Protege5 fitment guide
    215/40/17; 215/35/18
    7.0" +45 and higher
    7.5" +48 and higher
    205/40/17
    7.0" +42 and higher; Barely making it
    7.5" +48 or higher, the +45 still worries me with this width on a 205.
    Mazda Protege Sedan
    Can run 2 to 3 mm less offset than the Wagon. Appears to have a little more room under the fender. As we've got no problems with wheelguuruu's 19's at all.
    BEWARE OF THE PASSENGER SIDE. IT will be the first to rub. hehe. Not as much negative adjustment on that side, even with camber bolts. Based on left hand drive. hehe.
    Hope this helps everyone. Please feel free to call us as we will be stocking the real good ones, quality, appearance, weight, perfect fitment. Plus you'll get your forum/club deal and the sanctity of mind that the fitment has my blessing.
    Be weary of the "local tire shop" as many have not done real time fitments prior to your consultation. Not even the manufacturers who create the fitment guide for the dealers have test fitted everything. It's based on patterns with fitments in the industry. Unfortunately, our cars veer off that line just slightly but enough to be very annoying and ****ty when you just bought wheels that you were told fit only to have them rub.
    We are a tuning shop and therefore specialize in certain performance oriented vehicles. Therefore do multiple fitments on the same vehicles with different wheels and so forth. We weigh them loaded and unloaded, tires and wheels. It's some good info to base your decisions on.
    2002 Protege5- "The Silver Bullet"
    Myspace.com/kartrebel81
    Sticky: Posting and You
    http://www.albinoblacksheep.com/flash/posting.php
    Thanks for sharing. You're now stuck
      Thanks.
        thx
          sweet info! we need a list like this for first genners
            im lookin at wheels for my 01 lx 2.0 with a 37mm offset am i goin to be ok with these?
              I just purhased wheels for my 2000 ES 15x8 with 0 offset ill have pictures up as soon as i put them on
                Will 17x7.5 with a 5x114.3 bolt pattern and a 45 offset fit on a 2003 es sedan?
                  The pitch circle is correct: 5x114.3
                  I'm not sure about the offset because the ES sedan and the P5 had a 16 x 6", +50 mm offset wheel while the MP3/MSP had a 17 x 7", +55 mm offset wheel.
                  For a complete list of wheel/tire specs, go to:
                    I have a set of 16x7.5" with +37mm offset. will this be ok for a BJ 1.8L Protege with 205 45 16s?
                      Welcome to CP.
                      The short answer is, I don't know. The best way to determine this is to use a wheel offset calculator:
                      Keep in mind however, that reducing + offset appreciably from the OEM value (+45 mm) places a strain on the wheel bearings.
                        I have a 2002 P5, and the wheels are looking pretty nasty with bubbling, corrosion etc. Is there a how-to vid or pics on best ways to clean them up?
