Front spindles 97+ escorts interchageable?
    I need to get new front spindle assy's for my 95 EGT. The axles are rusted into the hub Does anyone know if i could use the newer escort spindles? I know there strust fit but not sure if the spline counts are diff or wheel offset.
    hello 4g63 nice to meet you
    is it just the axle nut that is rusted? if so just burn the nut off
      and cook the wheel bearings???:microwave
        If they come with the 22-14 calipers then yes. If they come with the smaller 22-13 calipers...then no
        Good luck man.
        JACK.
          all 97+ escorts use the larger front brakes, and yes the spindles are 100% compatible . ABS crap may be a little more common, but everything still fits the same with or without it.
            Sweet! thanks Jon. There easy to find compared to finding 95 or lower.
              So if you swap the front hub and brake equipment to the 97+ then it's an upgrade correct? If so woohoo. jy time.
                no...
                97+ escort/zx2 = 91-96 EGT = 90-94 protege LX
                it would only be an upgrade if you have a DX or a 323, or a base model (pony) 91-96 escort.
                  what do you think transmission shops do when they cant get axles nuts off they burn them off
                    doesn't make it right, i used to do collision work and we used to use an air chisel and that was a last resort.
                      no...
                      I wonder if there is a differents from the GS to RS front (MX3)
                      Mx3 RS,BP-turbo
                      http://www.cardomain.com/ride/2628805
                        the front brakes are all either 9.x" or 10.x"
                        so if you have 9" brakes then yes you could upgrade to the larger ones . not sure what mx3's came with.
                          I found a 97 kia today in the JY. I think im going to get the tranny axles and spindles for it. They want 200 for it all. The kia's have bigger brakes and appear to look like they will fit behind the stocks wheels. Anybody know if this is true?
                            NOOOOOOOOOoooooooo mike you should get the tranny and axles and sell them to me! :D
                            i dont think anyone has ever fitted the kia spindles/brakes. are they really bigger? are you sure it was a 97 and not a 98? because in 98 they changed a lot... went to all korean construction.
                              i dont think the kia brakes and spindles fit, but I could be wrong. it will be awesome to see if they do
