Megasquirt Ignition Advance Maps
    your map based accel enrichment is the cause of your oscillations:
      2012-05-03_21.23.02.zip
      I changed it to 2k, it has gotten a little better
        you need a wideband to get it any closer, do have one thats just not hooked to the MS?
        also your TPS mat and coolant temps look alittle noisy
          Yes I have an aem
          Where do I change that other stuff?
            noisy signals are usually grounding issues not settings.
            you should hook your AEM up to the Megasquirt's input so we can see your air fuel ratios
              I have it hooked up... I can see the AFR on the gauges I dunno why it doesn't show up during data logs
                thats odd,
                it "looks" like once the fans or whatever load causes the 800rpm idle that you marked in the last log can be fixed by changing the 50kpa row from 42 42 36 to 36 36 36 around idle, that much fuel extra will make it stumble more then it should. again thats guessing as i cant see your AFR in the logs.
                  where do I change that the fuel table?
                    ve table look at the 50 kpa row at 500, 800, and 1400 rpm points
                      b.zip
                      heres another from today
                      i added a new gound to the TPS
                        I flashed the firmware yesterday.
                          Can someone post their AFR chart?
                          My car is running rich alot of the time Id like to get that sorted out.
                          Whats your guys fuel economy?
                          I'm getting 300km per 40L of fuel
                          19Mpg which seems quite low for this car I expect to get more around 25
Name:	Dyno Graph.jpg
                            Evo3 16G @ 9 psi.
                              Any body got a good tune for my bp-t festiva? Specs
                              Mazda bp 1.8l
                              Forged cp Pistons 9:1 comp
                              Forged eagle rods
                              Walbro 255
                              Rx7 550cc
                              Acl rod and crank bearings
                              Stratified ms2
                              Arp head studs/ main cap bolts
                              T3/t4 ar.60 ar.63
                              8psi spring in tial 38mm
                              Ran a 13.4 but was popping at high rpms. Thanks Lmk
