vacuum hose routing
    vacuum hose routing
    what do you feel the best way to route vacuum hoses for MAP based standalone is?
    for example.
    i have three things in the dash that need a vac signal:
    megasquirt
    analog boost gauge
    electronic boost controller
    right now there is a T going between the gauge and MS, the EBC isnt installed yet. i do get a bit of map signal noise. mostly when i am in boost. i'm considering:
    a vacuum log, fed by one large hose, then split off to all three things.
    two hoses from the engine, one for the MS, one for the other two things
    -or- one hose for the gauge and one split between the MS and EBC
    anything you add to a vacuum signal will affect its response. This is why I suggest you run the MS alone off the manifold.
    Run the boost controller and gauge off the same line. Also why aren't you using the MS based boost controller?
      because MS2 doesnt have a boost controller
        MS2 extra does though
          yes but i dont have that lol. and i didnt even know that existed when i bought my boost controller.
            The nice thing about MS boost controllers is that you can set boost based on RPM which I don't think any commercial controllers can do.
            Did you bump the boost already?
              not yet... the 550's came in yesterday. i am hoping to install those and the boost controller this weekend.
              that is a nice feature... the greddy i have definately cannot do that. i may have to look into MS2e...
                that feature is well worth it - prevent some wheelspin and get some nice topend and the modification will cost you no more than $20-30 including the solenoid.
                  *completely changes thread topic*
                  so are you using MS boost control? what solenoid do you use?
                    Nope, have not done the hw modifications yet although I have all the parts. The solenoid most people use is off the GM Typhoon (the turbo Jimmy).
                      vacuum hose routing and length has an almost unmeasurable effect on MAP sensor response. Air has so little inertia that you can make the vacuum lines hundreds of feet long and it'll only delay the MAP signal a millisecond or two, which isn't enough to affect anything greatly.
                      Ask me about engine management!
                        I am not worried so much about hose length, I am worried about devices attached to the same line that may have leaks.
                          same thing applies there... if there's a leak anywhere in the system, it'll show up everywhere else.
                            Haven't tested myself, but I am guessing transients do show up and may results in the amplification of erratic readings.
                              transients? nah, a vacuum leak is generally pretty constant, unless the MAP rapidly changes (which seals up the leak generally for a split second).
                              What I was trying to get at is that if you have a vacuum leak ANYWHERE, nothing in this world is gonna stop it from screwing up your readings
