Dome Light Doesn't work and is wired up.
    Ok. everything is wired up. It also has a bulb in it. But it doesn't light up when doors are open or the switch is in the on position. What could be the problem ?!
    Bad bulb?
    1990 Protege 4WD
    1 3 5
    2 4 R
      no.. the bulbs are good. its just it still won't work. could it be the whole dome light piece ?
        bad ground?
          Those things ground via the mounting screws.
            my dome light, ignition light, and cargo light dont work, i think they are tied together.
              I don't know.
              For me it was a bulb that I thought was good, but then I replaced it anyway and it works ever since. After I took it out one of the ends fell off. The element was fine.
              1990 Protege 4WD
              1 3 5
              2 4 R
