Roll Call 4WD Proteges!!!
    The usdm 4wd protege trans is full time 4wd... it's just an open diff whereas the gtx/gtr transmissions are vlsd center.
    1988 White GTX - #1 parts
    1988 White GTX - #5 Rally car
      Thanks TOOOONS dude.
        Well I suppose its time for me to introduce myself.
        I just picked up a 90 4wd 5speed. Its kinda beat up and needs body work. But I already have a bpt/trans sitting in the garage for it, so thats pretty cool. I also have a 88 gtx, a 90 miata, and a 2000 miata that I'm planning on selling once the weather breaks in the midwest.
        So yeah, this is pretty much my first post on the cp forums. I guess you could call me a refugee from the old 323performance forums. Just saying hi to everybody here and its good to become a part of this community. Take it easy.
        Paul
        1988 323 GTX 5 speed
        MODS: It's my garage art
        1990 Miata 5 speed
        MODS: Awaiting on GM goodness...
        1990 Protege 4wd 5 speed
        MODS: BPT/AWD swap, JSPEED Coilovers, MS3PRO
        2000 Miata 5 speed
        Stock with Bilstein Suspension Package
        Chillin in the backyard with a rod knock
          Paul
          Welcome to cp Pual. Sounds like you're going to have a beast on your hands. Good luck
            haha... i totally never knew your name was paul... or id forgotten.
              well when talking about you to derrick, I just refer to you as 808.
              1990 Miata 5 speed
              2000 Miata 5 speed
                matt-bob works. he'll know who that is.
                  Im pretty sure usdm trans is not full time 4wd unitl you flip the diff lock switch. And yes its a open diff in the front and in the rear stock. So really when you flip the switch your only puting power to one front wheel and one rear wheel cause of open diffs.
                  Boosted 1990 4WD
                    It's full time 4wd with open diffs. Call it Any Wheel Drive.
                    1990 Protege 4WD
                    1 3 5
                    2 4 R
                      thank you. yes it is full time 4wd. 3 open diffs. when you lock the diff it gives it perfect 50/50 power distribution front/rear. though with the open front and rear diffs it doesn't matter it's still gonna transfer power to the slipping wheels in the front and rear.
                        I got a shifter and linkage now so I'm good had to get it from CO
                          I've got one!!
                          Ok, well, I've ALMOST got one. Deposit has been put down on it, I'll be picking it up in the next few weeks sometime.
                          It's the same one that jjmundt bought...
                          1990 Protege AWD 5spd...steel blue with nasty beige interior.
                          Found in Denver, CO. July 31st. Purchased August 3rd. 158k miles, worn clutch, very dirty interior, a ding or two in every panel, very minor rust bubbles around windshield. Runs good but needs just about everything, but it was perfect for the $900 I spent.
                          BPT/GTR candidate and am hoping for an interior color change to charcoal/black/something dark.
                          Car now resides with me in the Des Moines, IA area.
                          It will be picked up and moved to the Baraboo, WI area. Dunno what I want to do to it right away. I've got a rallyX on September 21 that it might be kind of fun to play with in stock trim. How dangerous would it be for me to engage the diff lock at a rallyX? rear LSD would be interesting, too. does anything else fit, or is the group A GTR diff the only one to look for? If memory serves (and it often chooses not to) isn't the miata ratio the same 4.105? do miata/RX7 diffs fit in the protege 4WD housing?
                          Fortunately, I've got my JDM GTX front clip, still hanging around, with the transmission, shifter, and everything else, so it'll get a better transmission eventually.
                          I'm thinking maybe a tightly-wound N/A BP, or possibly a full-on BPT setup. Haven't made up my mind yet on that front.
                          I'll definitely be soaking in the knowledge vat when it comes time to play with this one..
                          --sarge
                            Mmmm, I have (for short distances) ran upto 65mph with the diff lock on, in wet snow. It sure was fun listening to the whirring of tires and then a small bang and dry pavement was found. oops. Nothing broken either! Soo, a short dirt rally should be fine, but once on you can't turn it off should the whole "4wd steering lock hop" thing bother you. I personally liked it. Made me feel like a truck
                            diff lock on varying traction surfaces = bad. lol
                            90-93 miata diff the same, just different housing. That's your best bet for a cheap LSD. the 94+ and RX7 used a larger diff, which you could attempt to shoehorn in there, but I don't know what the ratios are, if they match up. I'd look for the group A if you're going all out.
                            I like the feel of a NA motor, but I think the BP is just too small to give me the tq I want. BPT all the way.
                              I'm just scared of not driving smoothly, and ripping some uber-expensive parts into little metal bits with too much torque. I mean, if I can snap axles with the MSP LSD in my wagon at an autocross..
                              --sarge
                                you want a 90-93 miata lsd, and you have to swap the ring gear from the stock diff onto it. its a different ratio.
                                oh yeah, i have a 4wd protege too
